popping in right front
Old September 9th, 2010, 11:12 PM   #1
96 Mustang GT
csfd127 is on a distinguished road
on my 96 gt there is a loud popping/banging coming from the right front wheel area when i turn sharply or hit a pot hole, also the car is all over the road. almost 2 inchs of play in the steering wheel? ? I'm puzzeled because the balljoint boots arent split.
Old September 9th, 2010, 11:18 PM   #2
KV007's Avatar
2003 Mustang Gt
Slow
KV007 will become famous soon enough
have you tried to get your front end aligned? fixes most problems
409rwhp at 4500 rpms.Vortech V1 Intercooled,kurgan motorsports powerpipe, 3.12 pulley, all Mac Exhaust,Sct Tuner,Bolt Ons,Cobra Brakes,MM cc plates,Vis 2000 cobra r hood,MGW shifter,Strange 31 Spline axles,Eaton Possi
Old September 9th, 2010, 11:32 PM   #3
96 Mustang GT
not yet, i was going to replace the front struts this weekend and then take it. just hoping to fix the popping while i had some wrench time on Sat.
Old September 10th, 2010, 02:21 PM   #4
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
check your tie rod ends and your front control arm bushings while your in there. If your struts are toast chances are they have been putting strain on other suspension components. You may also want to check out your steering rack bushings.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old September 10th, 2010, 04:28 PM   #5
wrestling98GT is on a distinguished road
i had the same noise and play in the steering wheel and i replaced the sway bar mount bushing because it was crumbling to pieces. handling problem as well as the loud noise went away completely.
Black 98 GT, first car, looking for all the advice i can get on modifications
Old September 10th, 2010, 04:33 PM   #6
Bringing Yellow Back
zinc-vert02's Avatar
2002 mustang gt
12.2 at 117
zinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to behold
Send a message via MSN to zinc-vert02
do you have caster camber plates? mine did the same thing and thats what is was, the ball in the cc plate get worn out and makes the exact sound you are talking about. so if you have cc plates thats probly your problem
SOON TO BE 5.4 3V POWERD WITH A ROUSH CHARGER HELPING IT
BAMA Performance Drag Team Member #4
Old September 10th, 2010, 09:48 PM   #7
96 Mustang GT
well i replaced my ball joints, tie rods, and control arm bushings today, i love when work is slow lol. after all that i find the camber/caster plates are making the noise, And the play is coming from the steering shaft where it comes through the firewall, the plastic bushing that keeps it snug in the rubber grommet came out . well its Coors time now. thanks guys for the help
Threads Similar to: popping in right front
front end popping billx55 96-98 7 August 23rd, 2010 07:55 PM
front end popping billx55 96-98 8 June 14th, 2010 10:35 AM
Front end popping Cricket 4V / SVT 24 February 24th, 2010 10:11 PM
Front end popping. weems 4V / SVT 4 September 5th, 2009 03:54 AM
Popping coming from the front fsttang96 96-98 3 July 7th, 2009 01:23 AM
