Tach Issues??? Need Help???
Old September 10th, 2010, 04:24 PM   #1
1997 Mustang GT
N/A
aaronbennett2 is on a distinguished road
I have a 97 Gt 5 speed and ever since i purchased the car the tach has been off in its own little world. The only time i get an accurate reading is when i am above 5000 RPM's, otherwise it just kinda floats around and does what it wants. Is this a pretty common thing for mustangs to do or is the dash bad or a wire loose or what? I have always owned diesels or carburated trucks never a fuel injected Ford, always been Chevy. Any help would be appreciated cause I really like to know what RPM I am at. Thanks
Old September 10th, 2010, 04:29 PM   #2
BAD98GT will become famous soon enoughBAD98GT will become famous soon enough
does it have a shift light that wired into the tach wire. if not check the wires that go to the pcm and at the back of the cluster and make sure they are making a good connection
Old September 10th, 2010, 04:30 PM   #3
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
No, that is not normal. Check the connector in the back. Make sure it's clean and properly seated in the cluster. The cluster is pretty easy to remove.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old September 10th, 2010, 04:44 PM   #4
1997 Mustang GT
N/A
no it doesnt have an aftermarket tach or shift light but everything else works in the dash, how difficult is it to remove the dash and take a look at the connector?
Old September 10th, 2010, 04:58 PM   #5
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
How to Install LED lights in your Mustang Gauge Cluster
This write up will show you how to do it. I used it to install led's in my dash and hvac lights.
MODS IN GARAGE
NCMM ORIGINAL
Old September 10th, 2010, 06:21 PM   #6
1997 Mustang GT
N/A
thankyou for that, it looks easy enough and i might see if i can get those led's anywhere around town and do that in the dash while im there. that looks alot cleaner and if im already that far into the dash i might aswell do it to. I appreciate the help. hopefully all it is is that the connector is loose, if not maybe find another dash that works.
Threads Similar to: Tach Issues??? Need Help???
Tach issues Firaga 5.0 Mustangs 14 June 9th, 2009 04:21 PM
tach install..... tach adapter 02S281 99-04 8 August 21st, 2008 01:35 PM
tach help please fast5.0lx 4V / SVT 2 April 22nd, 2008 03:34 PM
Autometer Tach/Tach Light and Ford racing Tach Driver install help 94stang 99-04 10 April 18th, 2008 11:35 PM
A tach ???????? lugthug713 5.0 Mustangs 4 December 25th, 2006 02:49 AM
