looks like oil in my coolant tank
LinkBack (1) Thread Tools
Old September 11th, 2010, 02:41 AM   1 links from elsewhere to this Post. Click to view. #1
96 PI is on a distinguished road
FYo Guys I have a 96 gt i aways had problems wit tha low oil light then I started to get oil in my tank so I did a full pi swap new gaskets, new oil, just got it back and still marking low oil and started to have oil back in tank I aways had a small leak in my transmission line. But it looks light brown not like transmission fluid
Old September 11th, 2010, 04:29 AM   #2
KV007's Avatar
2003 Mustang Gt
Slow
KV007 will become famous soon enough
sounds like a blown headgasket ??
409rwhp at 4500 rpms.Vortech V1 Intercooled,kurgan motorsports powerpipe, 3.12 pulley, all Mac Exhaust,Sct Tuner,Bolt Ons,Cobra Brakes,MM cc plates,Vis 2000 cobra r hood,MGW shifter,Strange 31 Spline axles,Eaton Possi
Old September 11th, 2010, 04:35 AM   #3
Yea but it has new gaskets
Old September 11th, 2010, 07:18 AM   #4
zdkel's Avatar
zdkel is on a distinguished road
what color is your coolant oil mix?
96 GT - PI Intake & cams, O/R h-pipe, Flowmasters - 40s, Short Throw Shifter, 3.73 FRPP gears.
Old September 11th, 2010, 12:42 PM   #5
BAD98GT will become famous soon enoughBAD98GT will become famous soon enough
i would have to say gaskets, even if new are you sure they were put on/torqed properly?
edit: are the heads warped or cracked?
Old September 11th, 2010, 06:01 PM   #6
Looks like light brown or like caramel
Old September 13th, 2010, 12:53 PM   #7
sj408 will become famous soon enough
well if you had a blown head gasket before you did the p.i swap might just be all the old coolant cycling through.
just saying because thats what happened right after i did my swap.
so i ran straight water in it for 2 or 3 days then did a coolant flush and filled it up with coolant and no more milky coolant my .02 cents
Old September 13th, 2010, 01:21 PM   #8
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.65 @ 115
sharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud of
iTrader: 10 reviews
Do this.
Sit outside with your car. Have it running and take your hose and put it into your resivoir. Then pull the plug on your radiator. Let it cycle the water through. Do this for like a half hour and it will be squeaky clea
410rwhp 520rwtq @ 12.9 psi
Old September 14th, 2010, 05:14 AM   #9
I already did all that cleaned it real good but still came back. I kno it's not a gasket otherwise it will overheat I'm thinking its a leak in my transmission cooler could dat b possiblem?
Old September 14th, 2010, 11:16 AM   #10
PhillyStyle's Avatar
2012 Brembo Mustang GT
PhillyStyle will become famous soon enough
Not true...it can still be a leaking gasket and not overheat..it depends on where the leak is. I drove my old car for months with choc milkshake in the resovoir before it begin to overheat and fail. I just kept cleaning it out while I prepared for the repair.
2001 GT Supercharged and Intercooled....387RWHP - SOLD
2012 Brembo GT
Old September 15th, 2010, 02:29 AM   #11
Just got back from the shop my mechanic told me it was the oil cooler, wat do yall think? Could that b the issue?
Old September 15th, 2010, 03:49 PM   #12
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
I could see that if it's cracked.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old September 15th, 2010, 07:46 PM   #13
Well I gotta buy this oil cooler for $450 Im hoping it fixes tha problem if not then I'm gonna shoot myself this car is starting to annoy me
LinkBack to this Thread: http://www.moddedmustangs.com/forums/96-98/182923-looks-like-oil-my-coolant-tank.html
Coolant Tank This thread Refback September 14th, 2010 10:53 PM
Threads Similar to: looks like oil in my coolant tank
coolant expansion tank pinder 99-04 2 June 22nd, 2010 10:04 AM
Coolant tank KevinJ99GT 99-04 6 March 31st, 2009 08:15 PM
Moroso 05+ Coolant Tank...... Jonathan@DRI 2005 - 2010 13 August 14th, 2008 08:55 AM
coolant overflow tank zhunter V6 Mustangs 10 November 24th, 2006 07:56 PM
