check engine light
Old April 2nd, 2007, 11:07 AM   #1
laserstang2's Avatar
laserstang2 is on a distinguished road
check engine light
well yesterday my check engine light came on
i installed the MIL eliminators like three weeks ago for my H-pipe
two days ago i got my subwoofer hooked up..maybe i rattled something that would trigger the check engine light??
does anyone know what all i need to check right now that might be triggering the malfunction lamp?
oh and i already checked my oil and fluids in the engine compartment..they are fine.
Old April 2nd, 2007, 11:39 AM   #2
thabagman001 is on a distinguished road
check engine light.
Remove your mass air senser and check the hot wires to see if there's any buildup on them,if thier is go to a office depot and get some electronics cleaner,do not use carburator cleaner,throttle boby cleaner or anything like that.those products have oil in them.What i did was use the cleaner from my K&N kit and the elctronic's cleaner.Once i cleaned it i removed the positive and negative battery term. let the car sit for 2hrs.then reconnect the cables and drive it for 1 hr.that will reset the computer.You may just need to reset the computer after you did the mod.Hope i could help.
Old April 2nd, 2007, 11:48 AM   #3
HMUSN's Avatar
iTrader: 9 reviews
go to a local auto parts store and scan the car.
(it's usually free)
then look up the code to see what is causing the cel.
Old April 2nd, 2007, 12:17 PM   #4
Casper98GT's Avatar
yeah no one can predict what it is. Just have the code read and then come back with a number.
91 LX, 5spd.
Ex:Toyota/Ford tech
Old April 5th, 2007, 12:27 PM   #5
thanks for the suggestions..it went off the next day for some reason, and i didn't even do anything to it but top off the oil and radiator fluid..i'm gettin a new battery sometime soon b/c some corrosion has started and i can't be havin' that
Old April 5th, 2007, 01:46 PM   #6
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
Out here none of the auto parts places will do a scan, but Harbor Freight sells a pretty good OBDII scanner for less than $100 (it goes on sell fairly often for $50). I'd suggest getting one, so you can scan the codes whenever they come up.
Also - there's 2 scanners that HF sells, get the good one, it's worth it.
O o
/¯/______________________
\_\
Buy my Bronco, special deal for MM folks
Threads Similar to: check engine light
check engine light 02ATIstang 99-04 24 May 22nd, 2007 06:03 PM
Check Engine Light brose1388 2005 - 2010 4 April 28th, 2007 04:26 PM
95 3.8L check engine light nikbait V6 Mustangs 3 February 24th, 2007 03:57 PM
Check engine light ByPopularDemand V6 Mustangs 18 January 9th, 2007 02:50 PM
Check Engine Light? GreenFaleen V6 Mustangs 13 November 20th, 2006 03:26 AM
