1998 mustang gt
new problem
took car to carwash sprayed on degreaser on engine while running then sprayed from a feet away and cleaned off degreaser after few minutes now the car is idleing rough like loping almost iv drove it around a lil bit and left hood up all day to dry it but its still doing it ang makeing lil poping backfires.any help would be apreciated.
2005 trd tacoma sport
your fucked.... great job at failing
j/k i say drive it so it can get hot enough to dry out then let it sit longer
1998 mustang gt
yea i took it for bout a 30 min drive then parked it for the night.hopefully itll dry whatever got wet.
Well if it back fires it's most likely ur coil paks or Could b ur tps
Hooo Ha Ha
Just go through all of your wires and check for water.
Look down your spark plug holes aswell and look for water.
![]() 410rwhp 520rwtq @ 12.9 psi |
1998 mustang gt
drives side spark plug hples are holding water im fixing to go try to dry it up ill let yall know what happens later
Rollin' 18/ pushin' 2
Your plugs are probably going to need to be changed.
98 GT, 93 Ranger!
![]() iTrader: 2 reviews
happens all the time to me. nothing big. no you dont need plugs lol. coils get water in them should go away in a couple days. normally takes about a hour or more of driving to get it all dry.
Threads Similar to: new problem
| just solved my evap problem now a more serious problem arises I NEED HELP please | sj408 | 96-98 | 5 | July 16th, 2010 08:12 PM |
| Transmission problem??? need help diagnosing the problem... | Tmac3320 | 99-04 | 19 | April 13th, 2009 12:58 AM |
| O Jesus! Problem After Problem! | mustangmanic | 99-04 | 94 | March 28th, 2008 03:36 PM |
| umm have a weird problem? idle problem? | blue03mach1 | 99-04 | 16 | March 4th, 2008 12:03 PM |
| Big Problem Or Little Problem? | wraitherx | 5.0 Mustangs | 17 | November 21st, 2006 08:45 PM |
