misfire problem, probelms, probably a problem?
LinkBack (1) Thread Tools
Old September 12th, 2010, 06:12 PM   1 links from elsewhere to this Post. Click to view. #1
rewadferger's Avatar
n/a
rewadferger is on a distinguished road
ok people i need a little bit of assistance, out of nowhere my check engine light came on, saying cylinder one misfire, here is what i have checked and or swapped out, and i really cant think of anything else that it could be.
step 1. swapped coil packs
step 2. swapped spark plug wires
step 3. swapped fuel injectors
step 4. swapped spark plugs
and it is still coming up with cylinder one misfire.
and i did not swap in new parts, just moved what was in there around, because what part it is would have making the other cylinder misfire, or atleast should have. and after every part i swap i cleared the check engine code. also it seems that the light comes on at idle after the engine temp reaches normal.
any ideas or anything is more than helpful.
96' GT
4.6L V8 2v non-P.I. w/ P.I. Intake
Ford Racing 3.73's, Aluminum Driveshaft, Hi-Flow 24lbs injectors, Hi-Flow Fuel Pump
Steeda Upper/Lower Arms, Under Drive Pulleys
Upr X-pipe, Magnaflow Mufflers w/turndown tips
Kyb Front/Rear Shocks
Old September 12th, 2010, 07:09 PM   #2
BAD98GT will become famous soon enoughBAD98GT will become famous soon enough
check your crankshaft sensor, it control the firing order. its located to the left of the crankshaft
Old September 12th, 2010, 09:37 PM   #3
n/a
alright i will check that, im guessing need to check the voltage on it?
96' GT
Old September 12th, 2010, 10:11 PM   #4
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.65 @ 115
sharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud of
iTrader: 10 reviews
check compression in that cylinder
410rwhp 520rwtq @ 12.9 psi
Old September 12th, 2010, 10:33 PM   #5
yes check the voltage and make sure its counting the pulses(signal)
also check the compression like shark said
Old September 13th, 2010, 12:17 PM   #6
Trick Tuners's Avatar
KB'd GT
yup, low compression can cause a misfire.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/96-98/183112-misfire-problem-probelms-probably-problem.html
Thread Sable Misfire problem | Auto Repair | BoardReader This thread Refback October 16th, 2010 10:04 AM
Threads Similar to: misfire problem, probelms, probably a problem?
Ford Mustang 5.0 Misfire Problem Help Asap bmxharo55 5.0 Mustangs 8 July 26th, 2010 09:02 PM
just solved my evap problem now a more serious problem arises I NEED HELP please sj408 96-98 5 July 16th, 2010 08:12 PM
Transmission problem??? need help diagnosing the problem... Tmac3320 99-04 19 April 13th, 2009 12:58 AM
umm have a weird problem? idle problem? blue03mach1 99-04 16 March 4th, 2008 12:03 PM
Big Problem Or Little Problem? wraitherx 5.0 Mustangs 17 November 21st, 2006 08:45 PM
