Gear swap...
Old September 13th, 2010, 09:13 AM   #1
Buck91 is on a distinguished road
Gear swap...
Considering swapping in some OEM Ford gears when I do my t-lok clutches and I got a couple questions. I'm familar with the 8.8 as I have swapped carriers in the past and I've done a bunch of homework on the DIY gear swap but a couple things aren't clear to me.
I plan on using a standard crush sleeve, so pinion spacing should be fairly simple. What I'm curious about is how simple it is/is not to replace the inner pinion bearing race or if its easier just to swap the bearing to the 'new' gears? What tools are needed, or is this best to just find a shop to press on/off?
Another related question: Does anybody know if the fluid specs for the carbon clutches is the same as the traditional clutches?
Thanks!
1996 Mustang GT 5spd - PI Cams, Bassani OR X pipe, Dynomax Ultraflow mufflers, C&L plenum with 75mm TB, K&N FIPK, PIAA 1700X foglamps.... More to come.
Old September 13th, 2010, 10:09 AM   #2
BAD98GT will become famous soon enoughBAD98GT will become famous soon enough
yes the fluid is the same, just make sure u use friction modifier.
the tools needed are a torque wrench, gear pullers, 27mm socket for the pinion nut and a 8mm wrench. a magnet helps also
Threads Similar to: Gear swap...
Rear Gear Swap Pricing and Gear Oil TStang 2005 - 2010 9 August 17th, 2010 06:09 PM
Gear Swap Please HELP!!!! pqtiii 2005 - 2010 8 May 4th, 2008 10:45 AM
91 Gear Swap Help 91cobra5.0 5.0 Mustangs 36 January 12th, 2008 05:55 PM
Gear Swap on a 98' Bpuckhead89 V6 Mustangs 1 July 18th, 2007 03:52 PM
3.73 gear swap droppedbass87 96-98 15 May 19th, 2007 11:08 AM
