2005 trd tacoma sport
getting so damn irritated with this car
my 96 cobra has an issue that if you free rev it the first rev it will rev second rev it will bog down third rev it will stall. when driving the car say i go from 2nd to 3rd hell 1st to second at say 3000 rpm it will bog down for a second then pick back up.
i replaced the fuel pressure regulator, fuel pump, and fuel filter the fuel pressure regulator is another new one. i havent driven the car long enough to know if it was a faulty fpr... being that the car is a return style fuel system i took the rubber boot off the return line due to it being corroded any ideas on what the issue could be oh at full throttle the car is fine. i did the test from the exhaust and the passenger side holds up the dollar bill but the drivers side doesnt keep the dollar bill up theres a popping in the exhaust. the car does have hollowed resonators and a exhaust leak on the passenger side collector on the header exhaust is frpp shorties bassani x-pipe flowdisaster 3 chamber |
check the tps. it should ohm out and then when you move the throttle to wot, the ohms should slowly(steadily)drop until its at wot
Captain Opinionated!
Well you kinda shot down all my guesses, so my next question is...do you have any pics of your car, she's purtyyyy
yea lol i do i have some of it with the 18s on it and the 17s
so it wasnt a faulty fpr.... now im at a complete loss. is there a way to tell if its the map sensor
if the tps was bad wouldnt my cel be on
ok ill try and check that out
Rollin' 18/ pushin' 2
I used to have a friend with a mystic. That thing was BEAUTIFUL!!!!
Priest of the Car Gods
When's the last time you seafoamed it? Seafoaming's the only way to clean the top end on b-ports (and no, fuel injector cleaner does NOT work).
If you haven't in a while, don't waste your time using it in the fuel or crankcase, just do the 1/3rd in the vacuum system.
i did it a few months ago. do you think the carbon built up to much on the imrc's while it sat therefore didnt allow them to open to get the car to start
KB'd GT
Try cleaning the IAC. 90% of idle control is the IAC.
It can build up quick. I'd seafoam mine every other oilchange.
i may seafoam it again then
honestly not sure wouldnt be suprised if they are deleted. is there a way to tell without taking the intake off
There is the control box with the cables attached, you can try to pull those cables. If no cables or control box, no IRMC.
Threads Similar to: getting so damn irritated with this car
| getting irritated fast | jasons_98gt | 96-98 | 12 | July 30th, 2010 07:24 PM |
| changing struts, irritated already | jasons_98gt | 96-98 | 29 | October 27th, 2009 08:11 PM |
| Damn My Car Is Slow | Youngin | The Clubhouse | 81 | July 14th, 2008 03:59 AM |
| My damn car went boom | 96Snaker | The Clubhouse | 38 | March 12th, 2008 01:43 AM |
| damn car wash | gooberhead320 | The Clubhouse | 11 | July 31st, 2007 02:16 AM |
