rockers
if your rockers come off will it act like it has a blow head gasket...i mean will it leak antifreeze into the oil..i pulled 1 cover off and 3 of the rockers are off on 1 side
no it wont leak antifreeze into the oil
Possibly you have dropped a valve? and it busted a piston or the cylinder wall and that could cause antifreeze to enter the oil. Happen to me once. Found out after I pulled the valve cover and see the rocker arm setting sideways. then i pulled the head and there was part of the valve stuck n the piston and 3 cracks in the cylinder walls. I didnt think I dropped a valve cause the valve stem was still jammed in the head.
1986 Mustang GT t-top time piece! |
Are you asking if it will mix if it possibly happens, or are you asking this because you have them mixing?
The rockers come off on the 4.6's all the time. Trucks and cars. They make a kit for a clip to put on it. But usually if you wind these things up to high rpms you will drop a rocker. But other times it just happens. So either it was something that happened or you have a problem with that cylinder. One of mine popped off....if you search for a post from me about "my lovely 98 gt" you will see i took pics of it and put it back on and drove away with no further problems.
91 LX, 5spd. Ex:Toyota/Ford tech Marine Machinery Technician, Department of Defense.
yea i have antifreeze sitting in the intake ports in the heads and was wondering if the valves would make that happen the car only has 70k on it and was never raced b4 i got it i let it sit and run for bout 20 mins and it shut off and hasnt started sence its been bout 5 months now and im just getting the money up to get it fixed...i have the pi head swap and intake to put on it so im hopeing its not a major problem with the block
Could be a cracked head. But that would mean you have piston/valve problems. But no, if the rocker comes off and you have coolant somethings wrong.
Threads Similar to: rockers
| Rockers | javier351lx | 5.0 Mustangs | 10 | October 8th, 2007 11:21 AM |
| oem rockers? | superman5.0 | 5.0 Mustangs | 2 | August 7th, 2007 07:37 PM |
| what rockers? | marks87gt | 5.0 Mustangs | 25 | April 11th, 2007 12:52 AM |
| rockers... | Fastpitchdad | 5.0 Mustangs | 2 | November 28th, 2006 10:08 PM |
| TFS And Rockers | jetpilot106 | 5.0 Mustangs | 6 | October 7th, 2006 01:58 PM |
