a couple newb questions.
Old April 4th, 2007, 12:36 AM   #1
product1620's Avatar
98 GT
14.60 @ 94.78mph
product1620 is on a distinguished road
Send a message via AIM to product1620
the 98 GT has a 5qt oil pan correct? and what psi do yall recomend for 275 tires?
Thanks
1998 GT
FRPP: 4.10s, Alluminum d/s
STEEDA:upper/lowers, springs, cc plates, tri-ax
TOKICO: Adjustable shocks
SPEC: alluminum flywheel
K&N: Intake
Screamin Demon ignition
ram: clutch
BUCK OFAMA
Old April 4th, 2007, 03:53 AM   #2
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
5 qts sounds about right, put 4 in and check it. If it's low, put another in.
For tires, I run a few pounds shy of whatever the tire manufacturer rated as max (i.e. My tires are rated 45 lbs max, I run ~42), but I'm going for handling/responsiveness/fuel economy, not traction off the line.
And I don't think you can determine appropriate PSI merely by the section width,
O o
/¯/______________________
\_\
Buy my Bronco, special deal for MM folks
Old April 4th, 2007, 10:26 AM   #3
Casper98GT's Avatar
It actually takes 6qt's with the filter.
Proper tire pressure is whatever you want. I would use the door tag. Thats what i always recommend. Look on youre door for mustangs i think its 32psi. The tire simply states how much tire pressure is safe for that load tire. Doesnt mean thats how much to put in.
91 LX, 5spd.
Ex:Toyota/Ford tech
Old April 4th, 2007, 02:01 PM   #4
Agreed, as a starting point. The part I disagree with is that number is usually intentionally lower than ideal for NVH reasons.
Your best bet is to run what you think, and if you get wear on the outsides of the tire it means you need more pressure, if you're wearing down the center, you've got too much, and if it's wearing evenly, it's just right. Proper pressure is going to depend on driving style - if you corner hard, you're going to have to increase your tire pressure to keep your tire wear even.
O o
\_\
Threads Similar to: a couple newb questions.
Couple a' Questions memphismustang87 Visual 0 October 9th, 2007 04:46 PM
Couple Questions Youngin V6 Mustangs 12 October 8th, 2007 09:49 PM
i have a couple questions rx1_ns 96-98 25 July 10th, 2007 06:25 PM
Newb here with some questions! 2ndChildhood 5.0 Mustangs 6 June 30th, 2006 11:21 AM
Hey, newb questions importtrndmustang 5.0 Mustangs 4 June 29th, 2006 03:31 PM
