96 cobra engine/03 cobra supercharger - Page 2
Old September 28th, 2010, 03:08 PM   #21
96 PI is on a distinguished road
Originally Posted by LGHTNG02GT View Post
the cobra crankshaft will fit.
the only cobra rods that came from the factory forged were the 03/04 cobras. they actually got manley rods right out of the box.
with what you have now, you should be at 10:1 compression or more. depending on power/boost levels you may want to drop down to like a 9:1 or 9.5:1 for a blower set-up so a dished piston would probably get you that.
Alright so 03 cobra crank and robs will fit in my gt rite? And dish pistons is a must. So what size of injectors should I use
Old September 28th, 2010, 03:11 PM   #22
I'm looking at 12pounds of boost or nothing less than ten
Old September 28th, 2010, 03:24 PM   #23
walt1120's Avatar
04 Stang 1.0Gallon V6
14.45 @95.8
walt1120 has a spectacular aura aboutwalt1120 has a spectacular aura about
well for 10-12psi id recommend 44# injectors minimum, if you wanna go higher boost maybe even 60#
what fuel pump are you gonna go with?
EDIT: 39#-44# should be enough, i thought you were procharging a 4v not 2v
2004 Bolt on & Cammed 3.9L V6
Old September 28th, 2010, 07:52 PM   #24
BlackSunshine
Guest
Posts: n/a
I would deff lower the compresion if you plan on running 10 to 12psi.. 9:1 comp at about 11.5 A/F ratio would be beautiful.. 10.5 A/F would be pretty consevative for DD..
Old September 30th, 2010, 06:21 PM   #25
so 03/04 cobra rods fit?
Old September 30th, 2010, 07:53 PM   #26
What about my rear end
Old September 30th, 2010, 08:33 PM   #27
BlackSunshine
Guest
Posts: n/a
Everything in a cobra block will fit your block.. It's essentially the same engine with better heads and intake..
Old October 20th, 2010, 11:51 AM   #28
Look Ma! My First Post!
nonwoven29 is on a distinguished road
If you don’t mind me asking how many miles are on that 96-98 engine and what is it going for??
I just got a 96 cobra engine with 40K miles on it with pcm, harness
Only damage in the accident was the 2 pig tails that lead to the coil packs where broken off and a little battery acid splashed one of the valve covers.
I’m trying to figure out the value of this thing and trying to make fair trades in my area and can’t seem to get an answer in today’s economy
Does any one know if I could take the pcm to a tuner and find the MPH at the time of the accident and the miles? I would thing there would me some kind of number linking the engine to the pcm. It’s been out of the car sense 99.
Thanks
Yo guys I want to buy a 96-98 4.6 cobra engine need to know if I could put a supercharger off a 03 cobra and wat would I need to swap engines need all tha help I can get
Old October 20th, 2010, 06:10 PM   #29
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
There is a write up about this on svt performance. You should check it out. It involves alot more than you realize.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Threads Similar to: 96 cobra engine/03 cobra supercharger
which engine for 1500 rwhp 2003 cobra 1999 cobra or 2000 gt gtjason New Members Introductions 14 February 19th, 2012 09:19 PM
99 Cobra Vortech V2-E supercharger kit on 01 Cobra? 01svtcobrajlt 4V / SVT 8 December 14th, 2010 10:35 AM
1996 cobra swap with 03 cobra heads and supercharger. stan's96snake 96-98 14 October 30th, 2010 03:57 PM
2003-04 cobra engine in 1996 cobra hedgehog 4V / SVT 6 December 9th, 2009 10:05 AM
can a 03 cobra Supercharger be put on a 97 cobra? 97Cobra 96-98 2 June 16th, 2006 08:51 PM
