Speedo Goes Crazy After 3 rpm!!! HELP!
Old October 8th, 2010, 01:27 PM   #1
Hunter97GT's Avatar
1997 Mustang GT Conver.
15.0@90mph
Hunter97GT is on a distinguished road
Exclamation
Hi guys just joined today i have never had this problem till yesterday i was leaving the Mustang meet. when i got to the freeway i got on it and suddenly my Light when off and came back on after a while. But not only that my speedometer went all crazy Battery Light Went up and everything in it got really bright! my Temp jumps up voltmeter Went off the scale!
Has any one else had this problem? its still doing it today only when i go above 3k RPM and i dont even need to punch it
Im gonna upload a Video on youtube then ill put the URL
Old October 8th, 2010, 01:47 PM   #2
Hunter97GT's Avatar
15.0@90mph
Here is the Video Of My Car Being a Bitch my Temp is good by the way just goes up when this Happens!
Oh Yeah and at night well well the whole Speedo Turns Really Bright and my HEad lights turn Of i got HID on them
Old October 9th, 2010, 05:26 PM   #3
MM's DRUNKEN SAILOR
deedub97GT's Avatar
single turbo in the works
as fast as i can push it!
deedub97GT is a splendid one to beholddeedub97GT is a splendid one to beholddeedub97GT is a splendid one to beholddeedub97GT is a splendid one to beholddeedub97GT is a splendid one to beholddeedub97GT is a splendid one to beholddeedub97GT is a splendid one to behold
Send a message via Yahoo to deedub97GT
the headlights going off is prolly your alternator or your hid are grounding themselves out some place. and the speedo sounds like you have a broken speedo gear. i cant get you a link right now but just google 1997 mustang GT speedometer gear and you will find the part its about 5-15 dollars and easy to install yourself. just have to know the size of your rear end gears. but before that i would check ALL your wiring. because you hids might be shorting out and causing the electrical side of your speedo (the ldimmer light) to go nuts like that.
and welcome to the forums
MILITARY CREW GSM3
i love throbbing meat
Old October 11th, 2010, 09:59 AM   #4
Hunter97GT's Avatar
15.0@90mph
Okay cool ill make sure to check my Hid out but this all started when i install the O/R H-pipe i never had this problem. but ill check the Cables. And ill look into that gear
If i get it Fix ill make sure to let everyone know here in case someone else has this problem in the future!
Thanks
Old October 11th, 2010, 04:51 PM   #5
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
Definately check your ground wires.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Threads Similar to: Speedo Goes Crazy After 3 rpm!!! HELP!
Speedo after gears. Where to buy gears and speedo fix... justinsstang V6 Mustangs 9 September 15th, 2010 02:57 PM
Performer RPM vs Performer RPM air-gap White 89 5.0 Mustangs 184 August 9th, 2010 01:35 PM
Cannot control RPM during ER Self-Test low RPM check. ddarkslayer 5.0 Mustangs 4 February 27th, 2010 04:03 PM
RPM stuck at 2500 RPM? Dawgfude03GT 99-04 16 October 3rd, 2007 09:21 AM
Crazy drifting / people getting owned by crazy drifting. MenaceToSociety The Clubhouse 8 December 14th, 2006 07:44 AM
