98 Mustang GT 4.6L v8
Intake manifold?
I have a PI intake kit from livernoise motorsport, someone had told me that I cannot get PI heads b/c I have this kit on there, that isnt true correct? He said something like it has an over sized rail on the sides that do not allow for upgraded heads, I think he is dumb, but I could be wrong. thought id ask
![]() 3:73 gears, Steed tri-ax, Mac o/r pro chamber mid pipe, w/ 2 chamber 2.5” Flowmasters,C&L upper plenum, Livernois PI intake swap kit, Steeda timing adjuster 16', FR 70mm throttle body, FR aluminum driveshaft, Lowering springs, BBK CAI Last edited by lilspanky9119; October 11th, 2010 at 10:15 AM. |
Hooo Ha Ha
If you have a PI intake theres no reason you cant get PI heads and put them on
![]() 410rwhp 520rwtq @ 12.9 psi |
thats what I thought, he must be dumb. Im looking into some PI heads as well. Whats the installation process like ? Shark bait I swear I saw the exact same car as you this weekend, ( the same from the outside lol )
![]() 3:73 gears, Steed tri-ax, Mac o/r pro chamber mid pipe, w/ 2 chamber 2.5” Flowmasters,C&L upper plenum, Livernois PI intake swap kit, Steeda timing adjuster 16', FR 70mm throttle body, FR aluminum driveshaft, Lowering springs, BBK CAI |
I don't see why not. If you install that intake on PI heads without the adapters, it should bolt on like it's supposed to. I think the platform for the plenum has been shaved for hood clearance which shouldn't affect the heads at all.
Hooo Ha Ha
PI heads and PI intakes are stock on the other GTs. They work together...also 99392309 people on this forum are pi swapped and it all works for them.
theres a thread around here somewere on the pi swap lol and you shoulda taken a picture. They probobly have good taste though also the PI intake isnt any taller. Fits fine under a stock hood.....i mean no were close to being an issue
Livernois modifies their PI intakes that come with the Non-PI adapters for hood clearance (due to the extra rise from the adapters). A PI intake will fit under a stock hood with no problems when the adapters are not used.
ok cool, thanks guys. So I will probably end up getting some PI heads, headers and a tune within a month or two. After that Im looking to get some cams.
If you're going to do the head swap yourself, I would wait until you have the cam's so you only have to do this once.
hmm...I will do that. I might just get headers and tune first, then go with cams and PI heads next. Good point^^ thanks. After these installs, the cams headers, heads, and tune I will be saving for forced induction..will be a longgg time but that will be my next mod to save for. Definitely want to go Kenne Bell, do it right.
Rollin' 18/ pushin' 2
pm sent
Hooo Ha Ha
97s281 if thats what i think it is...
then that mofo is one lucky mofo
+1 I remember this statement from Livernois site.
96 GT - PI Intake & cams, O/R h-pipe, Flowmasters - 40s, Short Throw Shifter, 3.73 FRPP gears. |
97 Mustang GT
slower than the speed of smell
i have pi heads if youre interested
Dang, every one of these threads turns into a classified ad. F***-it... I'm about to post my PI heads in the classifieds. They are '02 PI heads with 15k miles on them and CompCams springs for cam's w/up to .550 lift.
. . . Got custom grind Kenne Bell blower cam's in 'em too. ![]() . . . Valve-covers included. LOL Last edited by Back2Mustangs; October 11th, 2010 at 10:59 PM. |
#15 | |
SA XD40
09 crf450x super motard. 06 f250 powerstroke 04 cbr1000rr 03 rsx-s |
#16 | |
Wow, I didn't even think of that. Lilspanky, can you post a pic of your current intake please. The only intake you cannot use with pi heads is a svo intake. We just want to make sure that isn't what you have on there now.
I have PI intake, im at work now but around noon I will take a pic and post it up here
Does it look like this:
![]() Or this: ![]() ??
#19 | |
need tuned
1 of 829 made Bright Tangerine Orange 10Lb Vortech V2,CXRacing FMIC MHS Stage 2 Blower cams,39# Injectors PI Intake,Ported and Polished NPI Heads BBK Headers,78mm BBK Throttle Body Mac H Pipe,2.5 inch Flowmaster Exhaust ,373 Gears |
Threads Similar to: Intake manifold?
| Swapping a 98 V6 intake manifold with for a 99 V6 manifold | 98mustang | V6 Mustangs | 6 | November 20th, 2010 11:20 PM |
| Non PI intake manifold vs Aluminium crossover Intake manifold | cedp83 | 96-98 | 6 | September 10th, 2010 03:45 PM |
| Non PI intake manifold vs Aluminium crossover Intake manifold | cedp83 | 99-04 | 1 | September 9th, 2010 02:04 AM |
| intake manifold ???? | monoxide83 | 96-98 | 17 | April 17th, 2010 01:23 PM |
| intake manifold | 5.0stang22 | 94-95 | 6 | December 10th, 2006 04:31 PM |
