1997 Mustang GT
HELP, Right Front
I am new to Mustangs, always wanted one and thru my m id life crisis bought me this 97 that has been modded a bit. My probelms are:
1. Right inside tire cupping bad, brand new tires 2. Had it alligned twice already 3. Makesa pooping noise when turning right at slow speeds 4. Angle of strut ( under hood view) is at least 1/4" differnece from the left ( meaning the angle of the strut looks to be going outward farther which makes me think cause neg. camber ) I have replace all tie rod ends, new hub assembly It is visibly obvious that the camber is way negative It has been powred with the ford shocks ( was told not more than 1.5 inches ) Could it be a possible bent strut??? Im runnin outta money quick on this one issue, i do have some skills with tools if I just knew what and where to check next.. Thanks guys in advance. |
1997 Mustang GT
I meant lowered with Ford Springs
Rollin' 18/ pushin' 2
You should just disassemble the right front suspension. If your strut is bent it will be pretty obvious once you have it out.
Threads Similar to: HELP, Right Front
| Steeda 9.5 in Front??? | king_Ahmet | 2005 - 2010 | 5 | June 27th, 2010 10:54 PM |
| Which front do you like better.... | ESG-642T | Pictures | 23 | April 27th, 2009 06:20 PM |
| new front | drazga97 | Visual | 52 | April 21st, 2009 09:21 AM |
| New Front | Monster90 | Pictures | 8 | December 30th, 2007 12:30 AM |
| Cobra front? ROUSH Front? or Mach1 Chin? | Chris02 | 99-04 | 11 | November 19th, 2006 12:10 AM |
