LinkBack (1) | Thread Tools |
#1
P1443 Evap code?
While installing the Xpipe today I checked the trouble code history and there was a P1443 Evap code. Can anybody help me with info on this trouble code
1998 Mustang GT
![]() iTrader: 2 reviews
Purge solenoid and purge canister. Could be either or. Or both. I had the same code and after going to 2 different shops and taking up four days I got it fixed. Also could involve the vaccuum hoses (cracked or split).
pi swapped and dropped sn95 |
Rollin' 18/ pushin' 2
The code can come on if your fuel level runs real low as well. Fill up the tank and see if that turns it off after about 50 miles or so. The second most common reason is a cracked vacuum line
Follow the vacuum line off the BACK side of your upper plenum. It will run to the 3 components in the evap system. There are two electrical components and a charcoal canister. The canister is the last part of the system and the rarest to need to be replaced. It is located inside the passenger side fenderwell. the easiest way to acess it is to remove the tire and fenderwell splash shield.
Im gonna check all of the vacuum hose to see if there are any leaks if not I'll order the purge solenoid and maybe the canister. I did some searching on the net and that looks like it might be the problem
1997 mustang gt
i have the same issue.
if at first you don't succeed, try a bigger hammer. it if doesn't fit, force it. if it breaks, it needed replacing anyway.
I had this code for a while on my 96 gt, and my fix was easy and zero cost. On a hunch I removed the solenoid valve (mounted on the firewall) and sprayed some MAF cleaner inside. I reinstalled without ever clearing the code. After a few days the code went off and has stayed off for weeks (after being on for much longer). So, I'd recommend trying this first if you have the time (plus checking vacuum lines as others have mentioned).
1997 mustang gt
i finally had a chance to fix mine also. went to the junkyard and for $4 i got a flow sensor and purge solenoid. put it on, cleared the code, and it hasnt came back yet.
so good so far.
1998 Mustang GT
I have the same code. the only thing I havent replaced is the canister. I just said screw it. Also mine wont come on unless I fill up. It stays off if i run under half a tank
LinkBack to this Thread: http://www.moddedmustangs.com/forums/96-98/187413-p1443-evap-code.html
| Thread Thermostat and evap code.... | Cobalt SS Network | BoardReader | This thread | Refback | January 26th, 2011 09:37 PM | |
Threads Similar to: P1443 Evap code?
| code p1443 help please? | sj408 | 96-98 | 17 | August 3rd, 2011 05:24 AM |
| CEL Code P1443 | MustangMo | V6 Mustangs | 8 | August 7th, 2008 04:40 AM |
| Code P1443 After using seafoam!??! | 97redgt | Modular Mustangs | 3 | September 28th, 2007 02:22 PM |
| p1443 where is the evap emissions valve? | born2mustang | V6 Mustangs | 13 | August 12th, 2007 05:42 PM |
| Code P1443 ? Please help | 97Cobra | 96-98 | 2 | April 16th, 2006 05:47 PM |
