Bent Strut?
Old October 12th, 2010, 08:22 AM   #1
WickedLEE69's Avatar
1997 Mustang GT
WickedLEE69 is on a distinguished road
Exclamation
Bent Strut?
1997 Mustanf GT, Ford Racing Springs lowered in front 1.5 inches.
Would a bent strut cause cupping of the inside of the tire and how do I check that the strut is bent?? ( And also transfer over to the other front tire inside cupping?
Please help.
Old October 12th, 2010, 08:25 AM   #2
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
Visually inspect the strut. I would disassemble that side of the front suspension and check all the components individually. Check all your bushings as well.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old October 12th, 2010, 09:49 AM   #3
1997 Mustang GT
I have also noticed that somethings sems foul with the top of the strut mount. It appears to of a different angle than the other side, my thinking would be to maybe tighten down the nut more?? would that cause damage and will it pull my inside tire more into proper camber??
Old October 12th, 2010, 09:51 AM   #4
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
Just take it all apart and inspect it. Tightening the nut isn't going to solve your problem if you have a bent strut or a bad control arm bushing. You should also pick up a set of caster/camber plates to correct your alignment AFTER you figure out what the problem is.
MODS IN GARAGE
NCMM ORIGINAL
Old October 12th, 2010, 09:55 AM   #5
takiller's Avatar
2003 Mustang GT
9.0 in the 8th
takiller will become famous soon enough
+1
C&L CAI, 75 TB, Plenum, O/R H Pipe, SLP LM1's (Dumped), Eibach SS, Tokico S/S, Moser 31 Splines, Cobra Diff, FRPP 410's, XCal 3 93 Tune
Threads Similar to: Bent Strut?
possible bent valves? gt40mustang 99-04 4 March 30th, 2010 02:14 PM
Mandrel Bent 02GreyStallion V6 Mustangs 9 February 24th, 2010 07:03 PM
Bent axle Smirnoff 5.0 Mustangs 10 April 1st, 2009 12:25 AM
bent kmember 99v6stang V6 Mustangs 6 March 26th, 2008 04:18 PM
Bent Pushrod Steves LX 5.0 Mustangs 1 March 13th, 2007 12:48 AM
