Assembling Bare PI Heads
Old October 12th, 2010, 01:40 PM   #1
Jedi
96GTNATE's Avatar
1997 Mustang Cobra
96GTNATE is on a distinguished road
Question
I Got a set of bare PI heads. I have all the valves springs and valve guides. I was curious if there was a good write up on assempling PI heads. Or is that something ill want to have a shop do?
All the parts are brand new however i plan to put better springs in them as ill be running a decent sized cam.
All this will be going on my 97 Long Block. Notched pistons to go along for clearance.
Any suggestions? Thanks!!
03 GT --- Sold
96 GT --- Sold
97 Cobra --- Current
Mods In Garage
Old October 12th, 2010, 06:53 PM   #2
rotten's Avatar
SA XD40
rotten is on a distinguished road
I would take it to a shop ,
My machine shop charges very little to asemble heads , I think with 2valve head I can get 5 angle valve job and assembled for 150ish .
09 crf450x super motard.
06 f250 powerstroke
04 cbr1000rr
03 rsx-s
Old October 12th, 2010, 09:21 PM   #3
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
not hard, i can do a lil write up w/ pics tomorrow for ya if need.
Old October 13th, 2010, 02:43 PM   #4
Jedi
96GTNATE's Avatar
1997 Mustang Cobra
Oh that would be amazing! Yeah if you could put something together i would greatly apreciate it
03 GT --- Sold
96 GT --- Sold
Mods In Garage
Old October 13th, 2010, 04:53 PM   #5
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
ok, give me a little bit and i will go get something together for ya.
Old October 13th, 2010, 06:38 PM   #6
Jedi
96GTNATE's Avatar
1997 Mustang Cobra
Ok cool. Thanks man i apreciate the help.
03 GT --- Sold
96 GT --- Sold
Mods In Garage
Old October 14th, 2010, 01:41 AM   #7
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
here ya go. please excuse the mess, i did this on my porting table with a head that is waiting for some modifications. i just did the one valve, but you should get the idea.
tools needed:
sping compressor/otc tool (what i used here), small screw driver with a magnetic tip (comes in handy), assembly grease/oil, and hammer (not pictured).
clean all your parts and have set out ready to install. put little bit of grease on the valve stem and tip (some people just use motor oil, but grease is ideal).
slide the valve thru the guide, and install valve seal. give small push to seat the seal.
take valve spring, put in place (stock springs have a top and a bottom. they will only go on one way), put spring retainer on top of it, have locks within reach and compress the spring. if you are doing this on a table with a small spring compressor or the otc tool like i used, i reccommend putting a rag in the cumbustion chamber of the valve you are working on. if using a pneumatic compressor or equivilent, then it of course it doesnt matter. you might have to use small screw driver to help persuade keepers into place, magnetic tip is to help retrieve keepers if you drop them.
Old October 14th, 2010, 01:47 AM   #8
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
now take the hammer and give the tip of valve couple light taps. this ensures the locks are installed correctly and secure. now you install lash adjuster (be sure cam lobe is up if cam is installed), apply small amount of grease on tip of lash adjuster and vavle stem, and i reccommend apply light coat of oil on cam lobe and roller of the follower as well.
if you put rag in combustin chamber, you will need to pull it out as for the next step requires the valve to open some. be sure cam lobe is up, compress the spring (might have to push down on valve stem for valve to go down at same time), and slide rocker arm in. once rocker arm is in, you are done
you can do more than just one valve at a time, i usually do both/all the vlaves for that cylinder at same time when i doing it on table. i took that one valve assembly apart to do this for ya, hope it helps. feel free to ask questions if something you dont understand.
Old October 14th, 2010, 03:11 PM   #9
Jedi
96GTNATE's Avatar
1997 Mustang Cobra
Doesnt seem to difficult. Great write up. Thank you very much
03 GT --- Sold
96 GT --- Sold
Mods In Garage
Old October 14th, 2010, 03:18 PM   #10
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
You should make this a sticky in the " bible " up top.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old October 14th, 2010, 03:30 PM   #11
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
your welcome
i can with that write up if thats the one you want. i will be doing mine soon after i get done with the flow bench and any additional porting i might have to do. i can do a nice set of heads instead of the dirty one i have there.
Old October 14th, 2010, 03:47 PM   #12
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
Totally up to you man. It's a great walk through either way.
Reps for the write up.
MODS IN GARAGE
NCMM ORIGINAL
Old October 14th, 2010, 08:13 PM   #13
330CubeGt's Avatar
1997 SVT COBRA
1996 Mustang V6
330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light
iTrader: 14 reviews
Nice and simple how to, nice work...
-04 IRS - Magnaflow - Wheel Replica - Autometer - FTBR - FRPP - SCT - Brembo - PRO 5.0 - BOI-
Old October 15th, 2010, 03:20 AM   #14
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
ok, stickied
Old December 13th, 2010, 03:57 PM   #15
08grabberv6's Avatar
08grabberv6 is on a distinguished road
Send a message via Yahoo to 08grabberv6 Send a message via Skype™ to 08grabberv6
Ok man i tryed to REP you again on this one too but it told me i had to spread it around...Nice write-up..guess your like a forum, sn95, super-genious or something
Cam
New 2008 Mustang V-6-$18700(SOLD)
Upgrades, Parts, Labor- $12300
Whippin a 8cyl ASS with a 6 Cyl- PRICELE$$
2004 MUSTANG GT 40TH ANNIVERSARY-$10,300
UPGRADES, PARTS, LABOR- $0
WTB: JLT CAI, MGW STS, SHORTIES, SUSPENSION!!!!
Old February 3rd, 2011, 12:44 AM   #16
BREDMAN's Avatar
1996 mustang gt auto
BREDMAN is on a distinguished road
thanks for the write up
Old February 3rd, 2011, 12:52 AM   #17
KV007's Avatar
2003 Mustang Gt
Slow
KV007 will become famous soon enough
very nice write up
409rwhp at 4500 rpms.Vortech V1 Intercooled,kurgan motorsports powerpipe, 3.12 pulley, all Mac Exhaust,Sct Tuner,Bolt Ons,Cobra Brakes,MM cc plates,Vis 2000 cobra r hood,MGW shifter,Strange 31 Spline axles,Eaton Possi
Old February 3rd, 2011, 03:19 PM   #18
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
youre welcome
Originally Posted by KV007 View Post
very nice write up
thanks
Threads Similar to: Assembling Bare PI Heads
Bare Metal 68 huntnwater Classic Mustangs 3 October 27th, 2009 11:17 AM
bare with me...where can i find 02gtmustang 99-04 3 July 13th, 2009 02:01 AM
Bare Heads Cricket 99-04 7 August 27th, 2008 02:14 PM
