I think my fuel pump is shi!^^!ng the bed
Old October 16th, 2010, 12:59 PM   #1
fmxona500's Avatar
1996 Mustang
I take myself way too seriously.
fmxona500 will become famous soon enough
Have a 255 walbro with a KB boost pump and I believe it's on it's way out.
Started last week on occasion the pump wont kick on right away. I have to cycle the key once or twice to hear it engaging so it would start.
Finally got a chance to run my fuel pressure yesterday.
Key on engine off, zero pressure
Key on engine running 30 psi w/ vac
Running w/ vac it bounces alittle under acceleration. Starts to increase pressure, then fluctuates between 28 - 34 before stabilizing at 30psi.
Running no vac 40psi
As soon as I kill the engine, psi drops to zero. What do you guys think? Pump?
Old October 16th, 2010, 01:04 PM   #2
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.65 @ 115
sharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud of
iTrader: 10 reviews
Fuel pressure regulator maybe?
i also though it was supposed to run at 30 psi
410rwhp 520rwtq @ 12.9 psi
Old October 17th, 2010, 12:31 AM   #3
1996 mustang gt
ryanbiggame is on a distinguished road
I'm planning to upgrade my stock fuel pump to a BBK 255 to support my pi swap, do I need to buy adjustable fuel regulator too? Or keep my stock one I got now?
Old October 18th, 2010, 09:24 AM   #4
p4ndiamond's Avatar
1997 Pacific Green Cobra
14.80 No traction
p4ndiamond will become famous soon enoughp4ndiamond will become famous soon enough
I would check the fuel relay first sounds like it could be that.
Old October 27th, 2010, 01:45 PM   #5
fmxona500's Avatar
1996 Mustang
Problem fixed. Frayed wires in the harnesses for the pump and boost a pump. Probably happened from that stupid tire I hit at 70 a few weeks back.
Threads Similar to: I think my fuel pump is shi!^^!ng the bed
Datalogging Fuel Pump Volts with a BAP and Fuel Flow Rates Trick Tuners 99-04 21 November 18th, 2010 08:44 PM
Where can i buy fuel injectors fuel pump maf stevo306stang 99-04 6 September 12th, 2010 12:55 PM
Boost-A-Pump or GT500 Fuel Pump? stanglifemike 2005 - 2010 64 September 21st, 2009 01:17 PM
Fuel pump question. Stock GT pump to GT (supercar) pump. Nate's4.6 99-04 15 May 14th, 2008 02:25 PM
