Brake lights don't work HEEELLPP!!!!!!
Old October 17th, 2010, 04:57 PM   #1
281SLEEPER2v's Avatar
2000 MUSTANG GT
13.03 @ 103
281SLEEPER2v is on a distinguished road
So I switched my brake switch and my brake lights still don't work. Any ideas??
VALLEY STANG
2v+Cams+Nitrous
stock longblock till she blows
Old October 27th, 2010, 03:58 AM   #2
s4l
s4l is on a distinguished road
Send a message via AIM to s4l Send a message via Yahoo to s4l Send a message via Skype™ to s4l
Bulbs burnt?
Old October 27th, 2010, 04:15 AM   #3
ok i have had this problem on my 04 sixxer and my sister 04 sixxer...and i can only guess it'll happen on my 04 GT sooner or later....let me guess all three brake lights are out...the fuse was good so you replaced the switch on the brake...well been there done that...turned out to be the little box that plugs into the switch...its that little box that has two wires going into it...turned out in both situations i had the box has a wire fried inside of it...
you can do 1 of two things...the first being the worst way...remove the box...cut the wires so you can splice back in later...take the box apart (4 sec's with a knife) and put the wire back in place...splice the box back in and there you go
or two...this being the best fix...remove the box like before...only this time crimp female ends onto the two exposed wires under the dash (the same female ends used for any automotive electricle)..now just slide the female ends onto the male ends that used to slide into the box...this fix not only takes care of the first issue of no lights but also prevents it from happening again
Threads Similar to: Brake lights don't work HEEELLPP!!!!!!
Brake Lights Help! 02MustangV6e9 V6 Mustangs 3 March 28th, 2009 09:07 PM
Brake Lights Help! 02MustangV6e9 The Clubhouse 6 March 28th, 2009 03:53 PM
HELP-Brake lights dont work 01 GT 99-04 3 March 30th, 2008 08:26 PM
Brake Lights Speedstang302 5.0 Mustangs 13 February 20th, 2008 10:06 AM
Brake Lights FunNquick 5.0 Mustangs 1 August 15th, 2006 01:36 AM
