difference between 96 and 2004 block
is there any difference in a bare 4.6L romeo cast iron block from 1996-2004?
Proud American
very few, but not enough to worry about!
so its possible to make a clone terminator engine from a 1996 block?
Proud American
yes but it will be a head ache and not worth the time or money! The cobra engines are DOHC meaning 4v where as the GT are SOHC meaning 2V. It will be cheaper and easier to just get a 4v motor to start with than make your 2v a 4v.
what difference is there in the block for a SOHC and a DOHC engine? I thought that the bottom end was pretty much the same between the two
Proud American
There are a few different holes for the different timing chains and things like that!
To sum it up you can take any modular block(4.6) and make it whatever you want. They all share the same basic demensions, internals ,heads and ect. are all compatable some just require minor modifications to get you where you want them to be. One thing to note if you want a 4 valve you need the compatable parts.
Threads Similar to: difference between 96 and 2004 block
| Boss block or Dart block??? | JONJON | 5.0 Mustangs | 48 | November 6th, 2007 10:37 AM |
| short block differs from a long block how? | mustangfox9091 | 5.0 Mustangs | 35 | September 26th, 2007 11:57 PM |
| what is the difference between a 2004 gt and 2004 40th Anniv | coreyfitz | 99-04 | 3 | August 10th, 2007 12:09 AM |
| Difference In 96 Block And A 04 Block? | sonicblue | Modular Mustangs | 3 | November 8th, 2006 09:12 PM |
| Stock Cobra Block and GT Block the same?? | bbrewer03 | 96-98 | 2 | August 26th, 2006 02:31 PM |
