96 Cobra /98 Mark VIII IMRC Compatibility
Old October 20th, 2010, 10:08 AM   #1
Ovrclck350 is on a distinguished road
I have a 96 Cobra that has the IMRC deleted. I also have a set of IMRC's from a 98 Mark VIII with controller (Gen 2, Non-vacuum controlled), etc.
Are these compatible? I've read the plug is different, but nothing about evertyhing else being compatible. I can re-wire a plug though.
And yes, I know about IMRC delete, and why. I'd just rather re-install them since I have a good functioning set....if they will work. I wouldn't spend the money to find a set, I would just live with it like it is.
And as far as the delete, the previous owner removed all the butterflies, and the controller has a relay ghetto wired into it to fake the PCM into thinking they're operating. I haven't looked into how he did it enough to know exactly what he did though....and I don't know if it was a function of a bad controller, so hooking it up to the IMRC plates I have laying around isn't a viable option.
Old October 21st, 2010, 03:29 AM   #2
LGHTNG02GT's Avatar
4V swapped '02 GT
(2v) 13.9@101
LGHTNG02GT is a jewel in the roughLGHTNG02GT is a jewel in the roughLGHTNG02GT is a jewel in the roughLGHTNG02GT is a jewel in the rough
iTrader: 10 reviews
the deletes themselves will fit perfectly. the lincolns use the same heads as your cobra does. cant answer on the plug thing though...not real hard to change that out though if it is needed.
BSD 100MPH Club
YMR #8975
4v Swap and a little Purple Bottle
MM Nitrous Club #7
MM Cobra Club #87
Old October 26th, 2010, 07:31 PM   #3
I'm not wanting to put the deletes on, I'm wanting to put the functioning IMRC's on. I traced the wiring to the relay, and so I have the Cobra end solved. Now I just have to find and cross reference the 98 Gen II Mark VIII IMRC wiring.
Old October 26th, 2010, 09:52 PM   #4
luckythirteengt's Avatar
1996 MUSTANG GT
luckythirteengt is on a distinguished road
Send a message via AIM to luckythirteengt
it should be the same i would use a power probe and test the lincoln ones you should be able to make them open and close .
3.73 ford racing gears BBK cold air intake bbk underdrive pulleys walbro fuel pump flow tech long tubes 2 3/4 " catless exhaust 18" fr500 replica wheels
Threads Similar to: 96 Cobra /98 Mark VIII IMRC Compatibility
mark viii vs cobra irs majorownage 4V / SVT 3 September 20th, 2010 04:34 PM
97 Cobra Ignition Coil Packs vs mark viii Speedy1221 99-04 7 August 24th, 2010 11:47 PM
Mark Viii to Cobra or GT tatersgirl1 5.0 Mustangs 0 November 19th, 2009 03:01 AM
97 cobra sc and 97 4.6 MARK VIII 32 VALVE sacpoole 4V / SVT 5 October 3rd, 2009 12:04 PM
