1996 mustang 4.6 ticking sound
there is a ticking sound coming from the lower front part of my motor it gose away at about 2500 rpms and its not super loud just something that bugs me. it dont stop if the ac is turned on so idk what it is any ideas would be great thanks ill try to get a vedio
mustang :: mustangbad001.mp4 video by 1badmaxx - Photobucket sounds almost like its the water pump to me and there is alittle play in it with the belt off
I watched your video, I hope its not more serious than your diagnosis. You could try the mechanic's stethoscope: use a 1/4-inch vacuum hose, put one end to your ear and probe the suspect components with the other end. 1) usually good with pin pointing sounds 2) this is dangerous and being careless can get you hurt - use extreme caution and I am not liable
96 GT - PI Intake & cams, O/R h-pipe, Flowmasters - 40s, Short Throw Shifter, 3.73 FRPP gears. |
i hope its not main or rod bearings i really dont wannt rebuild the car i just got
96 Frankenstang
I have the exact same problem I posted it on here last week. Well to make a long story short my #5 piston has 0 compression looks like I am buying a new motor. Here's the link to mine you can see if you think it sounds similar, my ticking started a bit lower than yours but after a few weeks it became louder.
drop shipping and e-commerce web design Last edited by jg42122; October 25th, 2010 at 07:27 PM. |
well if its a bearing then im out 1800 bucks for a car i cant aford to fix right now. i guess if it dose turn out to be that ill build the bottem end but i really just wanted to keep it a stock bottem end and turbo kit
how likly is it that its a bad timing chain?
02 Mustang GT
sounds like timing chains/guides to me.
2003 Mustang Gt
Slow
![]() iTrader: 2 reviews
hows your oil? mine will tick if the oil ever gets low
409rwhp at 4500 rpms.Vortech V1 Intercooled,kurgan motorsports powerpipe, 3.12 pulley, all Mac Exhaust,Sct Tuner,Bolt Ons,Cobra Brakes,MM cc plates,Vis 2000 cobra r hood,MGW shifter,Strange 31 Spline axles,Eaton Possi |
i sure hope thats all it is .oil is full
2003 Mustang Gt
Slow
hmm ive never heard of our timing chains having problems/ needing to be replaced
1998 Mustang GT
13.8 @ 99mph
![]() iTrader: 1 reviews
Could also be the chain tensioner. It could be collapsed.
Car's out back ![]() "Excuse me,
Your balls are showing." ![]() |
2003 Mustang Gt
Slow
i read a whole thread here once a couple months ago where a guy was asking if he should replace his timing chain since he was already there and everyone said no. they had 150+ to 200+ and never replaced theirs or had any problems
Always a Newb
1997 Mustang GT
Ouch man! What ever it is it doesnt sound good! zdkel has the best idea. That will also work with a long scewdriver or a long extension
its the timing chain waiting for vid to upload now
97 Mustang GT
if it is coming from the lower part of your engine then it can be the oil pump it is located right behind the harmonic balencer.
Always a Newb
1997 Mustang GT
That aint to hard to fix. Justs takes a little time. Hope you get it fixed, let us know
mustang :: timingchain001.mp4 video by 1badmaxx - Photobucket im pulling the motor this weekend and rebuilding it. turns out its also low on comp in almost every cly
Threads Similar to: 1996 mustang 4.6 ticking sound
| help with ticking sound!! | lownoma1 | V6 Mustangs | 7 | September 6th, 2010 10:59 AM |
| ticking sound | KrazyStang | Modular Mustangs | 0 | August 7th, 2010 12:41 AM |
| help with ticking sound | Reggedon | 99-04 | 14 | April 20th, 2010 10:46 AM |
| ticking sound. | cobrasvt_585 | 94-95 | 4 | September 18th, 2009 12:20 PM |
| Clutch Ticking Sound | TheTechnical99 | V6 Mustangs | 11 | November 12th, 2006 10:42 PM |
