spark plug issue
i wanted to do a compression test so i went to take off the spark plugs and they was very hard to get out and was almost seized into the head now i wanted get the new plugs or the compression tester back in the holes they will thread in abit then stop liek there is dirt or **** in the threads how do i go about cleaning them out o is it best to buy a tape abd retape them to really clean them up
Hooo Ha Ha
Remember we dont have that many threads. So you may actually be at the end of the threads. Take a cue tip and tape it to a pencil. Spray some wd 40 on the cue tip and go around the threads
![]() 410rwhp 520rwtq @ 12.9 psi |
where do you get a foot long cue tip at lol. yes i know there is not many threads but it feels like i get one and they stop kinda like cross threading something but i knwo im not
Rollin' 18/ pushin' 2
If the threads were cross threaded the threads on the plug you removed would be screwed up as well.
i work for tires plus and we just had a customer do his own tune up. he now needs a motor lol. he didnt blow out the spark plug "hole" before removing the plug. there was a bunch of sand in the head and now it is inside the motor. he then cross threaded a few of the plugs. we were able to tap the head (on the car) and get the plugs in there (after spending a lot of time making sure we got out any metal shaving from tapping the hole) the car runs a little better but he has low compression on cylinder 2,3 and 4 and smoke from the pass side tail pipe. the sand messed up the ring seal to the cylinder wall (basically acted like sand paper on the cylinder walls). this is a very common problem (sand in the motor after doing plugs and also cross threading the plugs or even having a seized plug come out bringing the threads with it) it sucks man....... oh well just use it as an excuse to do an upgrade.... ported heads, pi swap, or even a 4v swap.
Threads Similar to: spark plug issue
| Champion Spark Plug 7989 Double Platinum Plug | UNVMYGT | 2005 - 2010 | 6 | November 24th, 2011 01:50 AM |
| 2002 gt spark plug issue | 0utcast | 99-04 | 6 | July 29th, 2010 12:25 AM |
| Spark Plug issue | naza | 99-04 | 7 | March 6th, 2010 07:46 PM |
| spark plug issue | SWEET2KSTANG | 99-04 | 35 | October 28th, 2008 11:26 AM |
| another issue with the spark plug blow out | 00redgt | 99-04 | 3 | October 8th, 2008 09:01 PM |
