Ported or PI Build - Page 2
Old November 1st, 2010, 01:51 PM   #21
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
But you have a more friendly CR with ported NPI heads on the stock bottom end than you have with pi heads on an npi shortblock. That makes them more boost friendly than running the p.i. heads on the stock npi shortblock. you can also run a higher lift with a longer duration with the npi's.
The difference in CR in the shortblocks is the dish on the pistons. The long block is different because of the piston's dish and the size of the combustion chambers in the 2 different heads. The motor I am building right now is using a .020+ bore 12cc dish piston with a 54cc head ( svo if ya didn't know ), with a set of matched cometic head gaskets. It's all forged. My CR comes out to be 9.01xxxxx. I will be running 9-11 lbs of boost with custom ground blower cams and a svo blower. Unfortunately, I will have to run a water/meth injection system to keep everything cool because you cannot intercool the svo blower.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old November 1st, 2010, 02:12 PM   #22
lilspanky9119's Avatar
98 Mustang GT 4.6L v8
lilspanky9119 is on a distinguished road
hmm...Sort of understand, remember I am new to this stuff. I am picking up on most of it though. I do plan on going f/i wayyy down the line so I will be sticking with the NPI heads and hopefully porting them soon. You can also go with more aggresive cams after you port the NPI heads correct?
thanks for all the information
3:73 gears, Steed tri-ax, Mac o/r pro chamber mid pipe, w/ 2 chamber 2.5” Flowmasters,C&L upper plenum,
Livernois PI intake swap kit, Steeda timing adjuster 16', FR 70mm throttle body, FR aluminum driveshaft, Lowering springs, BBK CAI
Threads Similar to: Ported or PI Build
ported tb twinmill 99-04 6 September 23rd, 2010 10:22 AM
ported or sealed? 97Roush 96-98 5 June 22nd, 2010 10:22 PM
Ported Intake Ticket-Me-Yellow V6 Mustangs 18 February 7th, 2008 07:24 PM
