suspension question
Old October 31st, 2010, 03:38 PM   #1
1998 mustang gt vert
98stanger is on a distinguished road
Send a message via AIM to 98stanger Send a message via Yahoo to 98stanger
suspension question
i know you are suppose to put this in the suspension thread but noone has answered anything since 2008 but i just rotated my two front tires and found that the outside edge and inside edge of my tires are bald with cracks going around the tires where the tread edge ends. im curious as to what could be causing this. just had it alighned a year ago and it went out of wack in like a month. didnt really think anything of it till i rotated them. any help would be appreciated
check out my garage for info
Old October 31st, 2010, 03:56 PM   #2
BAD98GT will become famous soon enoughBAD98GT will become famous soon enough
wearing on both the inner and outer edge of the tires is due to under-inflation or lack of tire rotation. so another words go check the air pressure nad rotate them every 5-6000 miles
Old October 31st, 2010, 07:43 PM   #3
i need rotating them every 3000 but i have bigger tires in back so i can only swap from side to side and air pressure is around 32 im thinking its tie rod ends or something
Old October 31st, 2010, 08:32 PM   #4
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
I hope you are not using a directional tire. You cannot rotate from side to side without dismounting the tires from the rim. Check your tires for an arrow. If they have an arrow pointing one way that is the only direction they are supposed to traverl regularly. ( Of course, driving in reverse is minimal and not a problem. ) If you are running them backwards they will get screwed up.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old October 31st, 2010, 08:49 PM   #5
directional in rear i know all about them and have been getting them rotated off the rims to another rim. the front ones are the stock tires that come on a 07 gt. the issue im having is the front tires. they are wearing on the ousides back and front and cracking around where the tread ends. it doesnt hold alighnment for long for some reason. i have a 2001 windsor engine thats built in it and i asked someone if the weight from that motor would do it and they said no. if you can text me and ill take some pics 276 340 2955
Old October 31st, 2010, 09:25 PM   #6
brandywine112972's Avatar
1997 mustang gt
brandywine112972 is on a distinguished road
your tire wear issues could be several different things.
positive camber wears on the outside
negative camber wears on the inside
toe in wears on the outside
toe out wears on the inside
ball joints, hub bearings and tie rod ends all need to be good and tight.
if they are faulty, it can cause various alignment issues.
i work at firestone complete auto care as a technician and do several alignments.
always if you get an alignment, go ahead and pay extra for a lifetime.
that way anytime you do any mods or replace any suspension parts, you get it re-aligned for free.
if at first you don't succeed, try a bigger hammer.
it if doesn't fit, force it. if it breaks, it needed replacing anyway.
Old October 31st, 2010, 09:26 PM   #7
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
Isn't the tire profile of the s197 platform kinda tall for an sn95?
MODS IN GARAGE
NCMM ORIGINAL
Old November 1st, 2010, 11:11 AM   #8
no they fit just the rims rub a lil in the front. im getting some spacers soon. im just wondering what the heck is making it eat tires like this. its crazy and i dont want to put new ones on till i figure it out
Old November 1st, 2010, 01:42 PM   #9
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
Sometimes it is worth it to see an expert. Whatever is wrong, it will more than likely cost you less to have fixed than to continue buying tires prematurely.
MODS IN GARAGE
NCMM ORIGINAL
Threads Similar to: suspension question
Suspension Question BlK2002GT 99-04 14 June 6th, 2010 08:56 PM
Suspension question fantas 2005 - 2010 11 May 1st, 2010 07:00 AM
Suspension Question.. ECUSVT31 4V / SVT 4 August 7th, 2009 09:47 PM
suspension question UrbanRedneck 2005 - 2010 6 February 23rd, 2009 10:37 PM
Another Suspension Question. 35th_Anniversary 99-04 6 December 15th, 2007 04:31 PM
