04 Cobra
Severly stiff clutch, completely stumped.
My buddy has a 98 cobra 5 speed. It is nearly impossible to get into gear so we suspected the pressure plate had bit the dust as per some of our ford mechanics we know. Long story short. We originally believe the clutch cable snapped but it didn't. The pedal dropped to the floor as if it did. Once it came back up it was completely stiff.
We ended up putting a new cable and quadrant on. Put in a new spec stage 1 clutch kit in. Went to press the clutch pedal in a couple times and where the quadrant mounts to the pedal assembly breaks. So we put in another pedal assembly and still the same issue. Would it be a TOB/Retainer issue? |
did u replace the pilot and the throw out bearings whenever you put the new clutch in? if not, that could be your issue. maybe the tob
04 Cobra
yeah we used the pilot bearing and the tob both that came in with the spec kit
did you grease the tob after you installed it.
and for future reference your better of getting a ford tob, theyll last the others you get in the kits a junk. ive used them once and never again. i buy a new clutch kit and new ford bearings(tob and pilot) |
only other thing would be tear it down and inspect the pressure plate.
i has a spec clutch that the fingers on the pressure plate bent a little only after a month |
04 Cobra
thats about what we got it down to. he put grease on the fork where it rides on that ball. I was figuring that or the retainer it rides on was screwed up. Should we get a ford tob just to be sure if when we drop the tranny to reinspect everything
i would def get a new ford tob and pilot
Threads Similar to: Severly stiff clutch, completely stumped.
| Stiff clutch | ocsailor86 | 96-98 | 2 | December 28th, 2008 07:39 PM |
| clutch stiff every now and then.. | soop7 | V6 Mustangs | 13 | October 15th, 2008 12:23 AM |
| Stiff Clutch | OcOnnor220 | 99-04 | 1 | January 26th, 2008 04:23 PM |
| Stiff Clutch | LUV2XLR8 | 2005 - 2010 | 15 | December 22nd, 2007 02:41 PM |
| stiff clutch | purplepony96 | 5.0 Mustangs | 1 | November 21st, 2006 05:00 PM |
