rebuilding my motor, wondering if i got all the parts
Old April 11th, 2007, 01:11 PM   #1
306ci 96 is on a distinguished road
im rebuilding my 281 2v out of my 96 gt
the block is getting stroked to a 5.1
i got pi heads and intake
comp cams with 550 lift
mac long tubes with non catted h
i got all the gaskets and other small stuff but im not sure if i should upgrade my injectors, throtle body ect
also, can i use my stock oil pan or do i need one with stroke clearance
Old April 11th, 2007, 01:16 PM   #2
Proud American
MustangMatt96GT's Avatar
Upgraded Valve springs for your heads!
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
Never Lift Racecars
Old April 11th, 2007, 01:19 PM   #3
whoops i forgot to add those to the list
i got those with the cam
Old April 11th, 2007, 03:30 PM   #4
would anyone know what injectors i should use
Old April 11th, 2007, 03:55 PM   #5
MM's nicest mod, :)
White99stang's Avatar
White99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to all
the 19lb injectors will work fine, if you can get a cheap used set of 24lb they would be ok also just cause they will have to work less
06 Dodge MegaCab Diesel 455rwhp/815rwtq
REAL TRUCKS DON'T USE SPARK PLUGS
Old April 11th, 2007, 04:50 PM   #6
Boomer is on a distinguished road
Send a message via AIM to Boomer Send a message via Yahoo to Boomer
I agree, you'll be almost at 90% duty cycle around 335 rwhp or so. Going with a 24 or 30 lb injector may be a wise investment however not nessesary. Do yourself a favor have the car tuned do not waste your money on a calibrated or larger MAF.
Old April 11th, 2007, 05:46 PM   #7
im deff getting it tuned when its done
would ibe able to use the injectors off of a dohc mark 8 motor
Old April 11th, 2007, 07:20 PM   #8
yes, I don't remeber what they come with (24's?) Just be sure to have it tuned for the injectors. Also you will be able to use your stock oil pan, if you plan to run a windage tray be sure to clearance it before final assembly.
Suggestion: I would not run a big cam (duration) with the added stroke as you are going to want to take advantage of the torque. I would suggest a reverse split duration to take advantage of the poor intake flow numbers, no more than 230 duration @ .050. If you would like I could spec you out a nice custom grind, PM for details if you are interested.
Old April 11th, 2007, 11:54 PM   #9
thanks but i already ordered the cam and the duration is 234 in and 238 ex @.050
Old April 11th, 2007, 11:55 PM   #10
white stang what stroke kit did you go with
Old April 12th, 2007, 12:11 AM   #11
Proud American
He went with the VT stroker kit with heads and cams from them as well!
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Threads Similar to: rebuilding my motor, wondering if i got all the parts
Rebuilding 289, what to use for better HP? nzmustang Classic Mustangs 12 July 11th, 2007 10:59 PM
Rebuilding transmission? gregkelley 5.0 Mustangs 1 March 19th, 2007 10:09 PM
Rebuilding engine the68stangdude Classic Mustangs 3 March 1st, 2007 09:38 AM
rebuilding engine... what should i get? Ninjawafers! V6 Mustangs 2 August 30th, 2006 09:49 PM
