mass air flow sensor
i got a used mass air flow sensor and i wanted to mount it in the cold air intake..is there a certain position the sensor should face? i understand the flow direction but the angle that its mounted?
2011 Mustang GT
The angle won't matter, just the flow direction. However keep it as close to stock as possible cause I don't think the wires are long enough to rotate it much.
![]() 2011 5.0 1.3 gallons of American performance!! K&N drop in (I know, I'm cheap) Flowmaster American Thunder exhaust H&R Super Sport springs Bremmer BR01 19x8, 19x9.5 wheels Bottomless bottle of soap! |
then how come when i turn it to the right a lil my car will stall when going around turns.....everytime
2011 Mustang GT
No telling. The MAF operates by heating a little coil and measuring the differance in volts based on the differance in temprature. It could be calibrated to sit in a certain position, but I've never heard that. For instance, many S/C, T/C and cold air kits move the MAF from it's stock location and it still works.
02 Mustang GT
not to be a jackass, but why are you adding a different maf sensor anyway? and a used piece of electronic equipment at that. were you sure it wasnt messed up when you got it? you dont really need a maf sensor unless youve got some form of forced induction and are pegging your stock maf out.
to answer your question though the maf should be on the top of the intake tube.
Threads Similar to: mass air flow sensor
| Mass Air FLow sensor | Maverick530 | 99-04 | 5 | December 3rd, 2010 05:37 PM |
| Mass Air fLOW sENSOR | Robert10 | 5.0 Mustangs | 1 | October 31st, 2010 01:58 PM |
| Cold air intake Mass air flow sensor | mike-oat | 96-98 | 6 | March 11th, 2010 09:57 PM |
| Mass air flow sensor | Paulnhbtx | 99-04 | 3 | December 31st, 2007 09:13 PM |
| Cleaning the Mass Air Flow Sensor | IcantDo55 | 5.0 Mustangs | 10 | June 26th, 2006 11:20 AM |
