2003 Mustang Gt
Slow
![]() iTrader: 2 reviews
Leak/questions underneath car
so i got underneath my car to see where it looks like it is leaking radiator fluid from, it looked like it was somewhere above the oil filter...
http://i1212.photobucket.com/albums/...2-02121630.jpg there is a spot here where there is supposed to be a bolt and there isnt any, another spot on the other side too. i believe this has to do with the transmission http://i1212.photobucket.com/albums/...2-02121600.jpg this cord next to the left cat isnt plugged into anything. it just sits there. http://i1212.photobucket.com/albums/...2-02121540.jpg EDIT: WOW FAIL, looking at this picture i see something i didnt see while under there, is it supposed to be plugged into that thing right above?
409rwhp at 4500 rpms.Vortech V1 Intercooled,kurgan motorsports powerpipe, 3.12 pulley, all Mac Exhaust,Sct Tuner,Bolt Ons,Cobra Brakes,MM cc plates,Vis 2000 cobra r hood,MGW shifter,Strange 31 Spline axles,Eaton Possi Last edited by KV007; December 4th, 2010 at 04:50 PM. |
2003 Mustang Gt
Slow
bump please help!
409rwhp at 4500 rpms.Vortech V1 Intercooled,kurgan motorsports powerpipe, 3.12 pulley, all Mac Exhaust,Sct Tuner,Bolt Ons,Cobra Brakes,MM cc plates,Vis 2000 cobra r hood,MGW shifter,Strange 31 Spline axles,Eaton Possi |
9k All Day.
MY00 s2000.
free
9k All Day.
MY00 s2000.
and yes, on that last one.
they look to be the same shape.
2003 Mustang Gt
Slow
yea :/ lol, anybody know what it does????
2000 GT 'vert
It's either the reverse lights or the speed sensor.. if you have a working speedometer, it's the reverse lights.
"...but don't say my car's topless, say the titties is out" Nas Last edited by bigjohnstud4200; December 5th, 2010 at 02:52 AM. Reason: added image |
2003 Mustang Gt
Slow
oh okay, i could swear both work lol
The coolant near your oil filter is likely a leaking gasket for the coolant/oil adapter block or it could be the clamp for the lower coolant hose.
96 GT - PI Intake & cams, O/R h-pipe, Flowmasters - 40s, Short Throw Shifter, 3.73 FRPP gears. |
98 GT, 93 Ranger!
I have the same problem on my car its either the oil cooler to block gasket or the oil cooler to adapter gasket.
2003 Mustang Gt
Slow
mine didnt start to leak till it got cold out?? did ur guys' leak like that
98 GT, 93 Ranger!
yes, mine would only leak if it dropped below like 40 degrees
2003 Mustang Gt
Slow
+rep thanks man
boost to come
1997 GT Vert
Yea mine did too, but it was the intake manifold. The gaskets had gone bad. That was where mine was leaking it looked like it was right above the tranny. I had somebody look at it though because i wasn't sure. The gaskets are only like 20 bucks at Advanced Auto but its a little time consuming.
2003 Mustang Gt
Slow
i just did my gaskets, hopefully they werent missaligned a little bit
1998 GT; 01 330i
As far as your missing bolt, that's nothing to worry about. It's for the front transmission cover, every trans-engine mount bolt holds it on and theres an extra 2 or 3 small ones the screw into the transmission side below where it mounts to the engine.
2003 Mustang Gt
Slow
oh ok thanks soupnutz
Threads Similar to: Leak/questions underneath car
| Anyone have pics of the underneath of a NewEdge? | Ke^in | Pictures | 5 | September 5th, 2009 12:42 PM |
| Hood PINS!! Installed underneath?? | Saleen0101 | Modular Mustangs | 6 | June 9th, 2009 07:05 PM |
| Thud coming from underneath my car. Help | ocsailor86 | 96-98 | 12 | November 10th, 2008 05:01 PM |
| When working underneath your car | Humphry | 2005 - 2010 | 24 | June 8th, 2008 11:46 PM |
| Pictures of stock front sway bar from underneath car | Kevin | Multimedia | 3 | January 3rd, 2006 05:14 PM |
