Easiest way to drain fuel from '98 GT Coupe
Old December 7th, 2010, 02:14 AM   #1
1998 GT Coupe
none
radarrunner1 is on a distinguished road
Have full tank of fuel and fuel pump went south. Tried to do the hose down the tank trick but cannot even hit fuel. Any easy way to drain tank? This vehicle is in my enclosed garage. Thanks...
Old December 7th, 2010, 02:27 AM   #2
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
there is an anti siohon device at the end of the filler neck. just get under there, and drop the tank. have some one there to help you slid it off you once its dropped. its a little heavy and awkward, but easily doable.
Old December 7th, 2010, 09:32 AM   #3
1998 GT; 01 330i
soupnutz is on a distinguished road
Does the pump work at all or is it totally dead? Reason I ask is, if it still works somewhat, you can pull off the fuel line at the filter, (direct it to a bucket or something), send some voltage to the pump, and empty the tank that way.
Old December 7th, 2010, 02:02 PM   #4
1998 Mustang GT
13.046@107.49
cruizer will become famous soon enough
if the fuel pump went bad, you're going to have to drop the tank anyways. Just get some help, loosen the tank, take out the filler neck, and tip the tank that way into a bucket. Or just drop it straight down. You can replace the fuel pump with the tank full. You will just need help to balance it when you are lowering and putting it back up.
Also, I used a floor jack with a 4ft 2x4 under the tank for added support so I only had to balance it, not hold the weight
98 Mustang GT 13.795 @ 98.87 N/A
Main mods: PI Swap, 3.73 gears, E85
My Mark VIII and T56 swap
Old December 8th, 2010, 05:41 PM   #5
1998 GT Coupe
none
Any one ever cut a window in the spare tire well? If so, I would be willing to cut a window with a small grinder and replace the fuel pump. I would need pics of the exact location and pattern to cut. If this is do-able. I would be willing to cut and fiberglass the cut panel back into place. Thanks....
Old December 9th, 2010, 04:08 AM   #6
1998 GT Coupe
none
How about a pic of the exact location of the fuel pump on top of the tank?
Old December 9th, 2010, 11:22 AM   #7
MikeHP350's Avatar
1998 Mustang GT Conv.
MikeHP350 will become famous soon enough
Send a message via AIM to MikeHP350
The fuel pump is inside the fuel tank in the center. When you drop the tank you'll be able to see where it is looking down on top of the fuel tank. Also, I would recommend purchasing a new filler neck grommet since your existing one will most likely tear during removal. They are 12.99 from latemodelrestoration.com
1998 Mustang Fuel Tank Filler Grommet by Ford at LRS - Same Day Shipping!
CAI, 75mm TB/Upper intake Plenum, Shorty Headers, Catted H-pipe, Flowmaster 40's, STEEDA U/D Pulleys, Sniper SF 93 Oct. Tune. MSD Coils/8mm Wires, NGK Iridium plugs, Full PI swap H/C/I, STEEDA adj. clutch cable/quadrant, RAM HDX Clutch.
Old December 9th, 2010, 11:35 AM   #8
MikeHP350's Avatar
Oh yeah, I once thought that my fuel pump had died however it turned out to be the Passive Anti Theft System.
Just incase you havent done so already,
Have you checked to see if the inertia switch inside the trunk on the left side under the paneling has popped up? If it has push it back down and try firing the stang up.
When you turn the key to the "On" position without cranking it can you hear the fuel pump priming at all?
Have you verified that the pump is getting the voltage it needs to operate right at the connector that connects to the fuel pump outside of the tank?
Old December 9th, 2010, 11:42 AM   #9
MikeD05GT's Avatar
2005 Mustang GT
MikeD05GT will become famous soon enoughMikeD05GT will become famous soon enough
Send a message via AIM to MikeD05GT
when i still had my 98, i was having a fight with my gf and smashed my keys against a wall out of rage...long story short the little white chip in the key itself fell out without me knowing and i went to start the car and it wouldnt turn over...had my dad order all the parts for a fuel pump which is what we thought it was and my brother was sitting in my car while we were getting ready to get to work and he noticed the chip was missing... thats why it wouldnt start... sorry to thread jack just wanted to share that im at jury duty and bored
Old December 9th, 2010, 06:50 PM   #10
fmxona500's Avatar
1996 Mustang
I take myself way too seriously.
fmxona500 will become famous soon enough
If you can't get fuel out from the pump, then when you remove the filler neck from the tank put your siphone hose through the hole in the side of the tank and drain it that way.If your tank is full, you're going to need three, 5 gallon buckets.
Old December 10th, 2010, 01:02 AM   #11
1998 GT Coupe
none
Thanks to all for all the great advice. I will attempt to drain and replace the fuel pump.
Old December 10th, 2010, 09:10 AM   #12
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
i pull full tanks out alone in 10 minutes not a big deal. DO NOT CUT THE SPARE WELL! your tank is directly underneath is ony 1/8in below if that.
Old December 10th, 2010, 11:38 AM   #13
Willy Mo's Avatar
Willy Mo is just really niceWilly Mo is just really niceWilly Mo is just really niceWilly Mo is just really niceWilly Mo is just really nice
not a good idea. if your dreading dropping the tank that much take it to a shop.
But really its not bad at all. Have a buddy help ya lower it.
Old December 10th, 2010, 11:44 AM   #14
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.65 @ 115
sharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud of
iTrader: 10 reviews
Willy its not as uncommon as you think to do that. Most camaro guys do that because of were there fuel tank is located. In my buddies camaro we would of had to drop the rear axle again to even get access to the fuel tank
But as Sweet said in our cars theres like 0 space between the trunk and the tank
410rwhp 520rwtq @ 12.9 psi
Old December 10th, 2010, 11:49 AM   #15
Willy Mo's Avatar
A lot of passenger cars have a window/door already in the car under the rear seat. So all you have to do is remove the rear seat and bam, your right there. I have replaced a couple fuel pumps this way, makes life much easier. Im not saying the idea is a bad one, but doing it to a mustang is a bad idea.
Threads Similar to: Easiest way to drain fuel from '98 GT Coupe
What's the easiest way too...? Lefty 99-04 13 January 24th, 2009 04:29 PM
Easiest way to drain tank /Starting issues Greybeard 5.0 Mustangs 7 January 18th, 2009 11:00 PM
easiest way to get badges off??? soop7 Visual 8 October 26th, 2008 06:44 PM
Cheapest easiest way JASonic V6 Mustangs 36 February 17th, 2008 03:09 PM
easiest thing for ME to do QuEeNiEsTaNg V6 Mustangs 65 January 9th, 2007 02:20 PM
