Discussing security troubles.... in the 96-98 Forum. hey my names travis im an owner of a 98 mustang gt. 4.6l sohc. ...
Old April 15th, 2007, 02:33 AM   #1
my problem is that i got an updated security system but i kept the old one in so i can pop the trunk and stuff, well lately the stangs been acting up and posting a security code on my reader(theft code). the car wont start, im not getting enough fuel to my engine(i need 40lbs), theft lights flashing,(even though the car is unlocked...)ive tried about everything, i guess my question is " if i take the old system out will it cure this problem, and if soo, how do i go about doing this." any help would be more then appreciated. thanks
Old April 15th, 2007, 01:40 PM   #2
The Great Unknown
Dennis-96GT's Avatar
11h47m32s
yea most likley the 2 systems are having issues coresponding id take the old one out mine still has the old one and i almost have to be in the car for it to work because the reciving unit is going bad so they have issues
MEMBERS AGAINST STREET RACING
Old April 15th, 2007, 07:08 PM   #3
Casper98GT's Avatar
If you have 2 systems normally the aftermarket system will cause problems. What they do is use an extra key and tape it to the PATS transponder. Aftermarket systems have known to cause problems especially in the starter if its remote start.
White99stang-
Damn i miss the good ole days, you know in 2005 when the site first started and everyone wasn't getting butt hurt over every little thing
Ford/Toyota tech.
93 LX, H/C/I + Vortech
Old April 15th, 2007, 07:16 PM   #4
so do you guys know how to go about taking the old one out?
Old April 15th, 2007, 07:53 PM   #5
wraitherlx's Avatar
99 Cobra
on alot of the aftermarket ones there is a thing that is called "starter kill" basically what it is is the starter wire is cut in half and then wired up to a relay. when the system is armed it leaves the circuit open so that if someone tries to take off w/ the car while its armed they cant. When it is disarmed it is the opposite the ciruit is closed sending power to the starter. You should try putting it in valet mode so that you can at least get into the car and start it. By old alarm are you talking about the "Factory"? If you are whoever you got the alarm installed by should have bypassed, or even interfaced, it with the aftermarket.
Old April 15th, 2007, 10:41 PM   #6
yes its factory, i can get the engine cranking but it wont start because im not getting enough fuel....its weird, but when i use my programmer and go into tunning my fuel gage goes back to 40lbs (were it should be) but when the theft lights blinking it will only give me factory fuel level. i have the factory fuel pump in the tank and a external vortec fuel regulator to bring the pressure up to 40lbs for my injectors...i dont now what to do. if i could get it started i could bring it to the audio place that installed it.
1998 mustang GT 4.6l-cobra R rims/Hood
-vortec supercharger(10psi) could (30psi)
-stage 2 cams-BBK shorty ceramic headers
-Flowmaster dual exhaust 3 1/2 inch
-3.73 gears-subframe connecters
-goodyear eagle F1
-sct ford programmer
Old April 16th, 2007, 09:17 AM   #7
Casper98GT's Avatar
yeah bro. forget about fuel. Its not gonna have any right now if pats wont let it start up. Bring it back to the place who installed the NEW alarm. Because its not working properly.
White99stang-
Ford/Toyota tech.
Old April 16th, 2007, 06:41 PM   #8
alright thanks alot guys.
-goodyear eagle F1
Threads Similar to: security troubles....
66 coupe security keefboz Classic Mustangs 26 March 8th, 2008 08:34 AM
security system mustang1072 V6 Mustangs 14 April 27th, 2007 12:24 AM
Security for my new ride Grabber427 2005+ 20 April 2nd, 2007 03:27 AM
New all pupose security system neckbonekat Videos 4 March 3rd, 2007 06:54 PM
Security System? mustangdude100 Electronics 4 July 22nd, 2006 12:22 AM
