Fixing fool.
Old April 15th, 2007, 01:07 PM   #1
Hudstang is on a distinguished road
Fixing fool.
Hey guys,
Been busy replacing rear brakes, IAC valve. It was to far gone to clean again, so put one one for $52.00. And changed my sqeaking idler pulley. I just could not find the exact torque specs. for the pulley, so I went 20 ft. lbs. You think that's a good number ? Walt.
Old April 15th, 2007, 04:25 PM   #2
Richs96 is on a distinguished road
All you need to do is snug it down, no need to be exact on the toque of it.
96 GT 5 speed
K&N w/Modified stock air box (Chep ass)
Flowmaster cat back
Tri-Ax Short Throw
PI intake to come
Old April 15th, 2007, 11:10 PM   #3
1998 SVT Mustang Cobra
1998_svt_cobra is on a distinguished road
Yeah, you don't have to be so exact with it because the pulley should rotate the same way that the bolts turn on so it's not like it will loosen up, it will only tighten.
Kennebell 2.1L Twin Screw soon tooooo cooome!
__________________^__________________
IT'S WATCHING YOU VETTE BOY
Old April 16th, 2007, 08:08 PM   #4
Thanks for the reply. Still have a belt or pulley squealing after acceleration. Now I'm thinking that the tension pulley needs to be replaced ? Changed the belt about a year or more ago with a medium grade belt. I'll have to check it out later this week. Walt.
Old April 16th, 2007, 08:16 PM   #5
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
IF YOU SPRAY THE BELT WITH A LITTLE LUBRICANT WHILE THE CAR IS RUNNING AND THE SQUEEL GOES AWAY YOU NEED A NEW BELT. IF IT DOESN'T GO AWAY YOU MAY NEED TO REPLACE ONE OF YOUR PULLEYS.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Threads Similar to: Fixing fool.
'00 GT's actin a fool again MSTGGT00 99-04 11 November 8th, 2007 04:29 PM
fixing a/c help AndrewA. All Other Vehicles 1 September 14th, 2007 06:17 PM
Fixing my speedo Ticket-Me-Yellow V6 Mustangs 8 May 9th, 2007 12:59 AM
Fixing Speedo Help Ticket-Me-Yellow Audio/Video 11 March 12th, 2007 01:30 AM
