Me and my 96 gt. - Page 12
LinkBack (5) Thread Tools
Old January 30th, 2012, 11:11 PM   #221
96-GT_Josh is on a distinguished road
Ok. When you say it was a pain how so? Just a tight squeeze?
IDK if going in from the bottom will be an option for me yet, but I will do everything I can to make it an option. Just gotta find a way to roll the whole assembly under the car all bolted together like that.
What did you do to roll that whole set-up under there and into position Rob?
Old January 30th, 2012, 11:37 PM   #222
NVMI just found a 1000 lbs movers dolly for 12 dollars at harbor freight. I guess that will be perfect for what I need.
Old January 31st, 2012, 08:30 AM   #223
MM's king of Neon's
WickedSnake00's Avatar
404 - car not found
17.81@87
WickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud of
Very tight squeeze, even with a load leveler. The two big pains were getting the longtubes to clear the K-member, and the massive heads to clear the heater inlet/outlets and brake booster.
Official Secondhand Snake Build Thread Here
Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra.
For Sale: P71 Interceptor motor
Old January 31st, 2012, 09:56 AM   #224
Yea i hear ya on the massive heads thin. Im doing this swap over my uncles and he has a 350 on an engine stand and i said that 350 looks tiny compared to this 281 and he said theres no way in hell thats a 281.
I said yup. He was blown away by that. He said that thing looks like a BB. Is it even gonna fit in your mustangs engine bay.
Pretty funny. Im getting it done though. Got the whole top side cleared. Now i just gotta pull the driveshaft and drop this beast outaa the M8 and start on the stang.
Old January 31st, 2012, 10:02 AM   #225
MM's king of Neon's
404 - car not found
17.81@87
I had a guy just randomly stop by when I was doing cams on mine.
He pulls up and says "Wow that's a big motor, I'll bet that will put down some big power. What is it, a 460?" "Nope. 281." "You're full of shit. What is it?" "I told you, it's a 281."
He then shook his head and took off.
Old January 31st, 2012, 10:18 AM   #226
Robs4valve's Avatar
96 gt, 4 valve
Robs4valve is on a distinguished road
Originally Posted by V8POWA! View Post
more pictures of the rims, been wanting to go w/ something like that!
Pics of Volk Te37's. volk te37 - Google Search
Jacking up the passenger side
96 Gt, 4v swap....Burns gas and rubber!!
Building; 98 Teksid, Manly 11cc pistons, Manly H beam rods, 98 forged crank, ARP throughout, C heads with a little exhaust porting and 98 cobra cams, 76mm PTK/custom turbo......Still just burns cash!
Old January 31st, 2012, 10:31 AM   #227
Robs4valve's Avatar
96 gt, 4 valve
With the engine, trans, and longtubes all bolted together. Would it be easier to drop the stock k and do it from the bottom or swing it all in from the top?
The only thing about going from the bottom Is you have to discinnect the ac and hydro boost lines for the power. The Heads are very large and it is a tight squeeze and with long tubes.... That would suck. The best part about going from the bottom is you have a ton of room to work with and you can install a 99% compleat motor rather than have to strip it down and reinstall every thing on it once it's in the car.
Robert
You can tell it's a small block when the heads are off.
Old February 3rd, 2012, 12:07 AM   #228
VaporS197's Avatar
2008 Mustang GT
VaporS197 is on a distinguished road
Rob, this build is the exact reason I'm about to get an SN95 right here! Like some have mentioned here already, I'm respectfully envious of your build. All day I've been looking for SN95s, and I think I found a couple in Jersey and PA, and I may have one of these by the end of next week. You've given me inspiration to get one of these things.
I just hope I don't have to get rid of my S197 to make this happen. But I'll keep checking back to this thread. Thanks for keeping us all up to date so we could live vicariously through you!
SMR #0513
Old February 4th, 2012, 12:12 AM   #229
whereat in Balto are you located? If you wanna stop by and see the 4v Swap inperson feel free.
Old February 6th, 2012, 09:26 AM   #230
Robs4valve's Avatar
96 gt, 4 valve
That means a lot to me. Thanks
Old February 6th, 2012, 12:21 PM   #231
Hey Rob, what did you do for the extra vacuum lines? The mark 8had an extra vacuum line running down to where the ac is for a egr crossover valve or something. Also it say in the how to that you can delete the air onduction system. What is that and how do i do it. Also im completely removing egr so what would ypu suggest i do with the extra vacuum lines?
Old February 9th, 2012, 07:13 AM   #232
Robs4valve's Avatar
96 gt, 4 valve
I started over with the vacuum lines. Their was just too menny of the hard plastic lines that would only work in the mark8 setup. I just ran new ones to all the things that needed it.
Old February 9th, 2012, 07:53 AM   #233
Also I see you have a 96 as well. Does the stock strut bar clear the MVIII inyake manifold? I guess I'll find out within the next couple days when i get my MVIII swap in.
Old February 11th, 2012, 09:50 PM   #234
Robs4valve's Avatar
96 gt, 4 valve
I thought I should share the building of the new motor.
It's a 98 cobra Teksid block and crank that I bored .020 over, And turned the crank .010/.010.
Block back from the machine shop
Brake cleaner spray in the oil passage ways starting at the top and going down just in case anything was left from machining.
Removing the coating from the polished surfaces with acetone
Main caps with bearings coated with Redline assambely lube.
Old February 11th, 2012, 09:51 PM   #235
Robs4valve's Avatar
96 gt, 4 valve
Crank video.
http://i146.photobucket.com/albums/r...f/2d89a101.mp4
Bering clearance looks good
Old February 11th, 2012, 09:51 PM   #236
Robs4valve's Avatar
96 gt, 4 valve
Rings
File fit for turbo
Rod caps off
Before cleaning with acetone
Clean
Bering in
Old February 11th, 2012, 10:00 PM   #237
Robs4valve's Avatar
96 gt, 4 valve
Pistons in!
Short block.
Head studs in
Canton windage tray
Old February 11th, 2012, 10:00 PM   #238
Robs4valve's Avatar
96 gt, 4 valve
Before it went in
Old February 12th, 2012, 02:44 AM   #239
p4ndiamond's Avatar
1997 Pacific Green Cobra
14.80 No traction
p4ndiamond will become famous soon enoughp4ndiamond will become famous soon enough
what kind of header is that ?
GT ENGINE (temporary) 4.30 Gears , 31 spline Moser axles , Detroit tru Trac diff, Jmod 4r70w , Pi intake Hitech stage 2 cam, Vortech V2 3.33 pulley. Alum drive shaft. Lowering kit x2 ball joints ,screamin demon coils, LCA "
Old February 12th, 2012, 08:09 AM   #240
Man this build just gets better and better.
Way to take it to the max!!
But when you first did the swap did you have a sensitive/lightweight throttle cable?
LinkBack to this Thread: http://www.moddedmustangs.com/forums/96-98/197318-me-my-96-gt.html
4v swap into 02 GT (auto) - Ford Mustang Forums : Corral.net Mustang Forum This thread Pingback August 3rd, 2011 12:14 AM
96 4valve turbo - Ford Mustang Forums : Corral.net Mustang Forum This thread Refback July 10th, 2011 08:45 PM
Now both my vehicles have 4 valve's!!!! - Ford Mustang Forums : Corral.net Mustang Forum This thread Refback February 13th, 2011 06:28 PM
Now both my vehicles have 4 valve's!!!! - Corral.net : Ford Mustang Forums This thread Refback January 19th, 2011 09:18 PM
Now both my vehicles have 4 valve's!!!! - Corral.net : Ford Mustang Forums This thread Refback January 19th, 2011 08:35 PM
