97 GT factory oil cooler delete? - Page 2
Old March 1st, 2011, 07:58 PM   #21
TheStangRay is on a distinguished road
Originally Posted by tri5333 View Post
O.K. replaced the P.O.S. Factory oil cooler with part# F2LE-6884-BD and no leak. I have put about 250 miles on it and its leak free. it required felpro gasket #70415 so make sure anyone doing the swap "DONT USE THE BLUE GASKET" it will leak like crazy the one you need will be red in color.
I have this problem right now Where did you buy the parts from? And about how much were they?
Old March 1st, 2011, 08:16 PM   #22
sn95mustanggt's Avatar
98 GT, 93 Ranger!
sn95mustanggt is an unknown quantity at this point
Well i replaced my adapter to block gasket and it still leaks coolant onto the ground. Any ideas?
1998 Mustang GT-S/C Teksid in the works
1999 Mazda b3000- DD
05 Rancher - 4x4
07 zx6r
2009 Kfx450r
yz 125
98 banshee- for sale
Old April 12th, 2011, 07:30 PM   #23
The Stallion mang is on a distinguished road
Krazy I had my Oil pan drain into my coolant system about 3 weeks ago. Got the block to adapter gasket (RED/orange one) replacet it flushed the entire system 5 times and had the radiator flushed seperatly put it all together. Fast forward three weeks to today getting ready to leave school and here is chocolate milk shake leaking from my radiator cap again. (same symptom as before) Checked the oil and sure enough empty. Brought it home and pulled everything apart AGAIN and the gasket looked fine and I believe was sealed up. I'm thinking the oil cooler itself might be cracked/leaking somewhere. There's no undercar leake just draining my pan internaly into the coolant system. To me it seems as though you don't need a whole adapter just a shorter one of the 1/2" allen type threaded bolt the filter screws on to. the adapter looks normal they just put an oil cooler in between the filter and adapter with a longer threaded shaft. Any one know the Part # of the shorter threaded shaft that screws into the adapter that the oil filter screws onto?????
Old April 12th, 2011, 09:52 PM   #24
1996 GT Vert
not sure yet
NatesGT is on a distinguished road
I respect ur opinions and suggestions shark!
Threads Similar to: 97 GT factory oil cooler delete?
a/c delete pulley/idler pullies, delete. casper gt 99-04 1 May 2nd, 2010 01:20 PM
oil cooler bullitt ak 99-04 1 June 8th, 2009 11:41 PM
oil cooler serjo 99-04 15 March 5th, 2008 07:44 AM
AC Delete and Smog Pump Delete triplethreatt77 5.0 Mustangs 14 December 24th, 2007 06:09 AM
