Discussing Tie Rods? in the 96-98 Forum. blah blah blah...thats all i see. i dont feel like reading all of that. ...
Old April 19th, 2007, 09:54 AM   #21
Casper98GT's Avatar
i dont feel like reading all of that. Jack youre car up. grab the wheel on the outer edges. Have someone hold onto the tie rod if it wiggles....replace it. Its SO easy. Loosen the 19mm nut place a mark then unscrew it and put the new on. Obviously remove wheel and take off 19mm nut on tie rod. Hit with hammer and it drops down. do the same on both sides.
Get alignment. BUmp steer shouldnt be a problem. If you read my link. If youre getting bump steer. Then like Uj. said caster camber plates should fit. If not...you have suspension problems. Also do you have the lowering rack bushings ?
The ball joints from steeda are for lowered cars as well. So if youre having bump steer, try that first.
To make this a long story short...buy some 20 dollar tie rod ends from autozone or local parts store and replace them./
If the place who did the alignment in the first place said they couldnt adjust them. they are fags. I havent met a tie rod i couldnt adjust yet. Except on Toyota trucks where they break clear off. BUT...Mustangs NO. Just get 2 new ones and be done with the situation.
White99stang-
Damn i miss the good ole days, you know in 2005 when the site first started and everyone wasn't getting butt hurt over every little thing
Ford/Toyota tech.
93 LX, H/C/I + Vortech
Old April 19th, 2007, 11:01 AM   #22
ujslost's Avatar
thats what I been saying!
Old April 19th, 2007, 07:40 PM   #23
All Throttle with a Bottle
MustangMatt96GT's Avatar
12.91@105.29 @ 5800 FT
Okay then I will be checking about the BJ here in a few minutes once I finish tiling! And then this weekend I will have something too do!! I do not have the lower rack bushings, but think that I will pick up some of those on Saturday and my Mustang shop! Is it a possibliliy that the bushings are just worn so that is why there is play in my steering? Thanks
We expect shit to break, look foward to realizing exactly when it is happening, and than obsess about dropping plenty of cash to rebuild stronger, so we can try to run it hard as hell and break again. We are sick individuals.
I support the MM Staff
Old April 19th, 2007, 07:45 PM   #24
ujslost's Avatar
the bushings probably arent worn
have fun tilling, I tilled my garden a few weeks ago and that damn tiller dragged me all over the place and im 5 ft 9 250
Old April 19th, 2007, 07:59 PM   #25
I wish I was tilling! I am cuting the tiles for my dad cuz we are retiling a bathroom!
Old April 19th, 2007, 09:52 PM   #26
ujslost's Avatar
ok never mind Im a dumbass, I read that to fast! No you rather do TILE than TILL believe me.
Old April 19th, 2007, 10:04 PM   #27
I earned all my money for my car doing gardens and lawns! I would much rather do tilling!! O well know I am going to go and jack up my car and check it out!
Old April 19th, 2007, 11:11 PM   #28
Okay so I got it in the air and could feel play in the toe but not the camber! From what everyone told me that would mean that I need new outer tie rods correct? I might just take it to my Mustang shop or my buddies brake shop and see if they will diagnoise it for free! Thanks and if you have anymore input that would be helpful!
Old April 20th, 2007, 04:21 PM   #29
ujslost's Avatar
im all out of info on this subject
Old April 20th, 2007, 05:04 PM   #30
Casper98GT's Avatar
um...im so lost right now.
Im gonna pretend i havent read anything yet....
jack up the front end and tell me where the "play" is...OK
And yes the rack bushings could very well be loose.
BUT you need to see where the play is first.
White99stang-
Ford/Toyota tech.
Old April 20th, 2007, 06:50 PM   #31
I can get my front wheels to move side to side! On the horizontal axis is where I am pushing and pulling at the edge of the wheel/tire to get the play in the steering! The steering wheel is locked when I do that as well. As for the vertical axis if I push on the top and bottom of the wheel there is no play! If you need more info I will be more than happy to jack it up again, and actually look at the steering when my dad is pushing and pulling on the wheels! I was alone last night so I couldnt really do both at the same time! Thanks!
Old April 20th, 2007, 07:33 PM   #32
ujslost's Avatar
then you need tie rod ends.
Old April 20th, 2007, 07:47 PM   #33
The more I have been thinking about it I think I need the new bushings more than anything, but we will see what casper says!
Old April 20th, 2007, 07:48 PM   #34
ujslost's Avatar
dude your killing me seriously!
Old April 20th, 2007, 08:07 PM   #35
http://www.allfordmustangs.com/Detailed/52.shtml
The rack bushings is what I think I need to replace! Please let me know! And I am asking so many questions because I dont have much money and dont want to be spending it on something that I didnt need!
Old April 20th, 2007, 10:28 PM   #36
ujslost's Avatar
im not sure how to tell if the rack bushings are bad
Old April 20th, 2007, 10:34 PM   #37
Okay srry for another question, but how would my outer tie rods be bad? just the actually threads on the tie rod or what? thanks
Old April 20th, 2007, 10:38 PM   #38
ujslost's Avatar
no not the threads, the tie rod is a joint, the joint gets worn out.
Old April 20th, 2007, 10:41 PM   #39
Oh okay thats what my other guess would have been! Thanks and I think I will wait til casper answers and then call up my mustang shop tommarow and see if what I describe is just bad bushings or tie rods or both! Thanks
Threads Similar to: Tie Rods?
Pistons Rods Bhblondguy 2005+ 3 November 7th, 2007 02:50 PM
Pistons Rods Bhblondguy 2005+ 0 November 5th, 2007 11:08 PM
texas hot rods??? White Thunder 5.0 Mustangs 13 November 4th, 2007 01:08 AM
Legand or TMD rods acmillr 99-04 9 July 1st, 2007 09:50 AM
question about my rods? kbstang 99-04 5 March 22nd, 2006 11:19 AM
