Tension Pulley
Old April 19th, 2007, 01:09 AM   #1
Proud American
MustangMatt96GT's Avatar
Tension Pulley
How hard is it to install a new tension pulley? Mine has started to make noise and would like to get it fixed and also like to know if I can WD40 it and see if that goes away! Thanks!
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
Never Lift Racecars
Old April 19th, 2007, 01:40 AM   #2
DragonFreak is on a distinguished road
Send a message via MSN to DragonFreak
its real easy
Old April 19th, 2007, 01:42 AM   #3
markush is on a distinguished road
on my 98 its super simple....i have to pull a coil a stopper plate then the tensioner...i thinks its a combined total of 6 nuts and bolts you have to undo. Even if the wd-40 stops the noise it will come back....for about 50 bucks for the tensioner and about 15 minutes start to finish you can fix it right.
Old April 19th, 2007, 09:55 AM   #4
Casper98GT's Avatar
yeah 98's they put pklates over them to not let water in. lol. It still gets in.
I recommend you going Gatorback belt after
91 LX, 5spd.
Ex:Toyota/Ford tech
Old April 19th, 2007, 11:12 AM   #5
IBEATU
stanglifemike's Avatar
06 GT, 98 GT, & 93 Notch
stanglifemike is just really nicestanglifemike is just really nicestanglifemike is just really nicestanglifemike is just really nicestanglifemike is just really nice
I have had to replace the one on my 98 twice already, and the Steeda crank pulley twice also.
98 GT: some stuff
06 GT: more stuff
93 Notch: 4 cyl at birth, now 5.0 drivetrain and stock exterior and interior= True Sleeper
Paxton/Vortech Crew Member #3
FRPP's #1 Dealer
Injected Engineering
BMR Suspension
Old April 19th, 2007, 07:41 PM   #6
Proud American
What will a Gatorback belt do for me?
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Old April 21st, 2007, 10:37 AM   #7
Hudstang is on a distinguished road
Some pulley info.
This may help, but I'm sure that you will have no problem with this project.I changed the pulley on the belt tensioner. It took about and hour with a no rush attitude and the part cost around $14.00 at murrys, made by gatorback. My understanding from Ford service that the torque is 25 ft. lbs for the bracket and pulley. The tools I used was a 13 mm open end wrench for the coil bracket, 10 mm for the smaller tensioner bolts and a 5/8 inch deep socket for the top middle bolt. The pulley needed a 15 mm . Walt.
Old April 21st, 2007, 10:45 AM   #8
HMUSN's Avatar
iTrader: 9 reviews
Re: Some pulley info.
i like this guy
straight up advice.
way to go man
Old April 24th, 2007, 11:57 PM   #9
Proud American
got it fixed and that is exactly what I did!
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Threads Similar to: Tension Pulley
TSB 07-20-3 Cable Tension Noise - Built before 12/01/2006 ujslost General Tech 1 January 18th, 2008 01:31 AM
new pulley chozen1 2005 - 2010 7 August 8th, 2007 01:06 PM
UD pulley is on ByPopularDemand V6 Mustangs 8 April 12th, 2007 05:19 PM
pulley help!!! 06harleysprayin 2005 - 2010 2 April 5th, 2007 01:54 AM
Gas Pedal Tension MSTGGT00 99-04 12 December 22nd, 2006 09:55 PM
