Coolant Problem
Old January 27th, 2011, 07:47 PM   #1
az98PIgt's Avatar
az98PIgt is on a distinguished road
Coolant Problem
Ok so while waxing the car today i decided to check all the fluids. Checked the coolant and its a dark brown and like mud inside the resevior. Now the car shows no symptoms of overheating or having a bad head gasket.
Specs on the car:
-98 GT w/a 2000 PI motor and transmission (only 50K on them)
I checked the oil and there is no coolant in it, checked the trans fluid (a/t) and it was still pink/red, also checked the power steering and it was normal color. So what can it be?
I was led in a couple directions such as a bad radiator (internal crack) or a bad oil cooler adapter that could leaking oil into the coolant...Thoughts?? Suggestions??
Old January 28th, 2011, 08:33 AM   #2
Tang Stang's Avatar
Tang Stang is just really niceTang Stang is just really niceTang Stang is just really niceTang Stang is just really nice
Did this suddenly happen, or have you not checked the coolant in some time? Are you running straight 50/50 water/antifreeze, or did you put an additive like water wetter in there?
Rod @ AzzKicker Cars
2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's.
1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC.
1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch
Old January 28th, 2011, 10:10 AM   #3
az98PIgt's Avatar
it was checked about 2 months ago when i installed a water temp guage and it was green. im using 50/50 mix no additives. Im thinking its the gasket on the oil filter adapter...gunna check that shortly
Old January 28th, 2011, 10:12 AM   #4
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
I have seen plenty of radiators get a light brown build up in them over time but not a dark brown like you suggest. I would change out the fluid and see if the discoloration comes back to verify if you are getting oil in your cooling system.
On a side note, i would recommend just swapping out your radiator for a new one rather than doing a flush / boil out treatment. Every time I have ever used the flush treatment it unlodges something that takes out my heater core. I mean every car, every time. A new radiator takes about an hour and a half to install tops and cost less than $200. Swapping out a heater core is a very lengthy and frustrating process that will take you a weekend to do and will cost you around $500 if you take it somewhere to have it done.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old January 29th, 2011, 09:18 PM   #5
96greenstang96 is on a distinguished road
Hi not sure if im in the right area just joined today. I have a 96 gt stick and i keep blowing radiators and i just wanted advice. I have a few mods, PI heads,manifold, Full length headers, mishimoto rad, EMP Stewart water pump. first mishi lasted 4-6 months replaced it with warranty. put new one in.// heater core blows out, bypassed it, month later radiator leaks bad again put stock one in and again same issue. could it be faulty rad cap, stat head gasket ??
Old January 30th, 2011, 09:38 AM   #6
mach1soldier's Avatar
mach1soldier is on a distinguished road
mishimoto radiators are known to fail quite often. Put an oem one back in there. Running your car a little cooler (180-190 degrees instead of 205-210) could help as well. Use the fan settings on your tuner.
2003 mach 1 12.7x @103 4600 stall, 4:30, slicks & skinnies, ALUM DS, VMP tune.
1996 ford thunderbird (13.02 @104) pi block, all the bolt ons minus cams, 3.73, 3800 stall.
Old January 30th, 2011, 09:41 AM   #7
Specs on the car:
I would suggest that before you do anything, drain the radiator fluid into a clean pan and then pour it into a clear jug. If you see oil floating at the top, then you know to check the oil filter adapter first.
If it is just dirt, it will be mixed throughout the jar.
Old January 30th, 2011, 10:31 PM   #8
wrenchhog44's Avatar
1998 Mustang GT
wrenchhog44 is on a distinguished road
It's not uncommon for internal engine problems to result in oil leaking into the water while not leaking water into the oil. However, I doubt this is your problem. I believe that it is more likely that a lage amount of sediment broke loose and dispersed in you coolant supply. I would reccomend having your cooling system flushed and keep an eye on your coolant level and condition.
When in doubt, go by the rule of dog...
If you can't eat it or f*ck it, just piss on it and walk away.
Old February 9th, 2011, 09:20 PM   #9
POWA! 24/7 fukkers
V8POWA!'s Avatar
1 @ 1
V8POWA! is a glorious beacon of lightV8POWA! is a glorious beacon of lightV8POWA! is a glorious beacon of lightV8POWA! is a glorious beacon of lightV8POWA! is a glorious beacon of lightV8POWA! is a glorious beacon of light
bro. i think this is happening to mine right now too. any update??
Old February 13th, 2011, 12:16 PM   #10
Not yet, but it cant be the mishi rad because i had put oem one back in and it did it to.
New Rad will be here in a few days and im just going to replace the stat and hopfully that will cure the prob.
Old May 13th, 2011, 01:34 PM   #11
(update) Rad cap pressure to high needed to go to lowerer PSI cap rating
Old May 14th, 2011, 02:25 AM   #12
canada_gt's Avatar
1996 mustang gt
canada_gt is on a distinguished road
weird
1996 gt new motor and hopefully more POWA
1988 5.0L lx sold
Old January 6th, 2012, 06:40 PM   #13
>>>>>>blown head gasket was the problem i believe<<<<<<
just progressively got worse till i noticed it was really pressurizing the coolant system. opened up cap and could smell exhaust lol. but oil isnt milky. Drove like that for a while surprised i didn't hydro lock it.Try to chang it out in the spring .>>>>> but came across a 94 mark viii with 50000miles on it going to swap it. lota good info on the swap around hopfuley make it a peice of cake.
Old January 6th, 2012, 11:47 PM   #14
p4ndiamond's Avatar
1997 Pacific Green Cobra
14.80 No traction
p4ndiamond will become famous soon enoughp4ndiamond will become famous soon enough
When i had that issue i later found out it was deteriorating heater hoses on the back of the intake. when it blew the INSIDE was dry rotten and i only found out because it blew off. after that it stopped doing this. I suggest inspecting them all before it becomes a bad situation.
GT ENGINE (temporary) 4.30 Gears , 31 spline Moser axles , Detroit tru Trac diff, Jmod 4r70w , Pi intake Hitech stage 2 cam, Vortech V2 3.33 pulley. Alum drive shaft. Lowering kit x2 ball joints ,screamin demon coils, LCA "
Old January 9th, 2012, 12:45 AM   #15
heater core blew a while ago i just bypassed it instead of taking the dash out. your talking about the hoses that go into the firewall right?
Old April 17th, 2012, 05:36 PM   #16
1998 mustang gt
stang98piswap is on a distinguished road
back to the oil in coolant problemo!! I flushed my system two months ago and the oily coolant is back... must be the oil cooler adapter gasket right?? how do i change it and where is it??
P.I. Heads/Cams, PI Intake, 80mm maf, CAI, ported C&L plenum, ported 70mm proproducts throttle body, 3.73 gears, manifold back {no cats} custom exhaust/side pipes, msd coils, Taylor 409 wires, two row aluminum radiator...SCT Livewire bamachips tuned
Old April 17th, 2012, 07:00 PM   #17
2v power
xandraxal's Avatar
96 Mustang GT
xandraxal is on a distinguished road
From what I understand, a blown head gasket wont mix water into the oil on a modular motor. I could be wrong though
Old April 17th, 2012, 10:50 PM   #18
1998 mustang gt
well i doubt it a blown head gasket... my problem is not coolant in my oil... but oil in my cooling system instead.... I've been reading its a common problem having to do with my engine oil cooler gasket?? anyone shine some light on this please
Old April 18th, 2012, 12:37 AM   #19
p4ndiamond's Avatar
14.80 No traction
Yes i have seen it happen a few times.
Old April 18th, 2012, 12:24 PM   #20
2v power
xandraxal's Avatar
96 Mustang GT
Yes, doubtful its headgasket. Are you sure its oil in radiator and not tranny fluid?
Threads Similar to: Coolant Problem
coolant problem :-\ dpbbnc89 99-04 16 August 3rd, 2010 08:22 AM
Coolant problem energiesource 99-04 2 January 8th, 2010 05:53 PM
Coolant problem ssprofession 96-98 13 January 27th, 2009 10:59 PM
Coolant Problem sn95cobra 96-98 6 November 8th, 2007 01:26 AM
Coolant Problem!! jkonfuzhon 5.0 Mustangs 5 February 19th, 2007 10:45 PM
