radiator fan not working - Forums at Modded Mustangs
post #1 of 7 Old February 14th, 2011, 03:59 PM Thread Starter
6 Time ROTM Loser!
V8POWA!'s Avatar
anyway i can check it. what fuse is it? anything else i can try, or should i just find a new one or something...
V8POWA! is offline
post #2 of 7 Old February 14th, 2011, 05:47 PM
sn95mustanggt's Avatar
A lot of times on the sn95's the fan itself is good its the connection. On my last sn95 i just made the fan manual on a switch because we or a shop couldnt figure out why it didnt work.
1998 Mustang GT-S/C Teksid in the works
1999 Mazda b3000
RZRs
RZR900XP
2009 Kfx450r
05 kx250f
Chevy CCSB
sn95mustanggt is offline
post #3 of 7 Old February 14th, 2011, 10:09 PM Thread Starter
6 Time ROTM Loser!
V8POWA!'s Avatar
alright. anyone know the number for the fuse? if there is one?
V8POWA! is offline
post #4 of 7 Old February 14th, 2011, 11:29 PM
check fuse,(look in owners manual or on the cover of the fuse box)mine show on back of cover
check relay,,(look in owners manual or on the cover of the fuse box)
check temp sensor, located on the coolant passage on the intake manifold, right behind the altenator- check ohms/resistance, should change as temp gets hotter.
iff all good disconnect the plug at the fan and check it for power. should have 12 volts when relay makes contact. if you have power then replace the fan. if no power you have a broken/shorted wire somewhere
BAD98GT is offline
post #5 of 7 Old February 15th, 2011, 01:01 AM
turn the car on and turn on the a/c and tell us if it comes on. if so it will be your relay sensor that is hooked up to the fan shroud. fan comes on with a/c on and doesn't ever with temp - relay on shroud.
jk_aktion is offline
post #6 of 7 Old February 15th, 2011, 12:48 PM
red01's Avatar
When mine went it turned out to be the pigtail on the connection for the temp sensor on the intake, the wires had broken apart inside the connector. Unplug it and see if the fan runs all the time, if so check the sensor and the connection.
Also check the CCRM, they are known to blow that fan relay.
1997 Mustang GT
04 PI 2V, bolt ons, gears, tune
255/292
www.covertmotorsports.net
red01 is offline
post #7 of 7 Old February 15th, 2011, 04:05 PM Thread Starter
6 Time ROTM Loser!
V8POWA!'s Avatar
ok so i tried it and it did turn on when i put the a/c on.
V8POWA! is offline
Human Verification
LinkBack to this Thread: http://www.moddedmustangs.com/forums/96-98/204166-radiator-fan-not-working.html
Where Is '98 New Beetle Radiator Fan Fuse This thread Refback February 25th, 2011 04:57 PM
