low oil light
Does anyone have this problem? my oil light is always on whether or not i put oil in it...its off when i get an oil change, but they it comes on...so i add some oil and it goes off for like a day and then comes back on...even tho there is plenty of oil
Is the sensor sticking to something in there? and reading wrong or what..
Proud American
Ive only had mine go on twice and it wasnt low on oil! I think it might just be a bad sensor!
EVO 8 @ 29psi
these mustangs are notorious for the low oil light going on especially if u park on a slight hill. i wouldnt worry about it although it is good to check it once and a while
2003 EVO 8 The shop built motor, Precision 6262 w/.82 hotside, tial 44mm wg, Buschur RACE 4" FMIC, Kelford 272s etc 524whp @25psi on straight pump gas. 640whp@33psi Pump+meth Race gas number soon. TheShopCt.com |
Smelly Fists, Socking Cocks
Millenium Falcon
I have a similar problem with my car. I basically check the fluids every day or every other day. I haven't had a problem since i first noticed the problem, but that was only about 600 miles ago.
Threads Similar to: low oil light
| Head Light and Tail Light Opinion Needed | Laser | Visual | 8 | January 2nd, 2008 03:16 AM |
| od light | 99bluev6 | Modular Mustangs | 12 | September 9th, 2007 11:01 PM |
| light bulb in dome light | myeleanor | 2005 - 2010 | 7 | August 31st, 2007 04:34 PM |
| ABS light | j2000_guy | 94-95 | 3 | March 29th, 2007 01:42 PM |
| How you can change your dome light color. (light on roof) | SonicStang | Visual | 25 | March 23rd, 2007 01:39 PM |
