97 GT Starting Issue
Old April 14th, 2011, 08:13 AM   #1
MustangTim is on a distinguished road
The last few times I've driven my car, it will "click" the first time I turn the key and start up normal the second time I turn the key. The "click" is the same sound you get when you have a dead battery, but it is just clicks once. Any ideas? Starter or starter solenoid on the way out?
Old April 14th, 2011, 08:16 AM   #2
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.65 @ 115
sharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud of
iTrader: 10 reviews
Check to see if the battery is dead
Then try having someone tap the starter with a hammer while you turn the key
410rwhp 520rwtq @ 12.9 psi
Old April 14th, 2011, 08:21 AM   #3
Wich88's Avatar
1997 SVT Cobra
Wich88 is on a distinguished road
^ +1. Start with the simple things first. Hopefully its not the starter, they are a B to change!
Old April 14th, 2011, 08:31 AM   #4
1996 Mustang GT Vert
Blower Head is on a distinguished road
Start at battery terminals making sure they are clean and tight. Then work your way towards the starter.
96 GT vert, Aftercooled Vortech, Lightning MAF,42# injectors, saleen cams, Bullitt intake, tune by Hitech, Magnaflow catback and O/R xpipe, Cobra brake upgrade, lowered bilstein suspension w/MM c/c plates and subframe connectors 3000 stall and 3.73's
Old April 14th, 2011, 09:01 AM   #5
I need to buy a new cable. It has the clamp-on style terminal now, which I don't trust. I cleaned and tightened them the first time this happened. The battery is fine. Like I said, single click first try, starts normal second turn of the key.
Thanks for the quick responses.
Old April 15th, 2011, 11:00 AM   #6
98 gt convertible x2
hlinar is on a distinguished road
It happened on my 98 Lincoln, turned out to be a weak solenoid. I replaced the whole starter. hey with 270,000 mi on the original, I figured it had earned a new vs solenoid only. They're right it was a b to change. heres a link 4.6 is a 4.6...
Lincolns OnLine | Tech Tips and Articles
Threads Similar to: 97 GT Starting Issue
Starting issue Ron4543 5.0 Mustangs 13 February 25th, 2011 07:03 PM
Starting issue 93notch matt 5.0 Mustangs 2 June 12th, 2010 12:56 AM
Help Please!!!!! Starting issue. orangerider32 5.0 Mustangs 4 October 29th, 2008 10:46 PM
starting issue white nite 5.0 Mustangs 28 April 16th, 2008 02:04 PM
Starting Issue G.T. Rags V6 Mustangs 14 January 8th, 2008 06:34 PM
