96 Gt Aftermarket Radio Help
Old April 14th, 2011, 04:24 PM   #1
96 Mustang GT
White96reborn is on a distinguished road
Question
keep in 96-98 forums please.
anyway i got a new kenwood radio from my buddy with a 89 5.0. i havent every hooked up a radio before but i know wires are colored to mean where they go. my question is can anyone get pics of which tubes of wires i need to open to get which wires. should i just open them all?? i am never selling my mustang so i dont have to worry bout putting the stock radio back in. also is there a black(ground) wire in the tubes or should i just bolt it to the dash frame? please post pics if you can i am a visual kinda person.(just easier) thanks guys
Custom 2011 Cobra Interior, 4.10's, K&N Cold Air Intake, Off Road X-Pipe, Super 10 Flows
Old April 14th, 2011, 06:12 PM   #2
Traction...?
1996 GT's Avatar
1996 GT/ 2008 GT Vert
1996 GT has a spectacular aura about1996 GT has a spectacular aura about
Not sure but if these are the same as the '96 because i just did one on mine. They person that had it before me he cut all the wires in the back including the big gray one, i may be able to find a wiring diagram if its the same?
Old April 14th, 2011, 10:20 PM   #3
WhiteNoise's Avatar
1997 Mustang GT
WhiteNoise will become famous soon enough
the diagram that came with the headunit is the same colors as the wires in the dash. U should mount the housing to the dash frame to keep it from being loose and rattle around. Sorry no pics of the installation but i just did mine not too long ago.
Mods: MAC o/r H, SCT tuner, CAI, short throw shifter, dash LED conversion Upcoming: Suspension build (Spring/Summer 2012)
Old April 15th, 2011, 07:29 AM   #4
1996 mustang gt
13.07@104.66
JK7208 is on a distinguished road
i had changed my head unit and used a plug and play addapter it plugs into the factory plug on one end and the other ends are all labeled and just need to be spliced together radio shack is where i got mine,
1996 GT 5-SPEED
PI SWAP Trick Flow 75mm TB/PL
BBK CAI, UDP, Mac Longtubes and offroad Prochamber SCT tuner
Seeda Triax Short Throw Shifter
3.73 Ford Racing gears
278rwhp/295rwtq
Old April 15th, 2011, 08:53 AM   #5
All Motor 1998 GT
cstreu1026 will become famous soon enough
That is the right way to do it. Go to any place that sells aftermarket radios and get the correct installtion kit. It will make installation a breeze and should be problem free.
Old April 15th, 2011, 09:29 PM   #6
1996 GT Vert
not sure yet
NatesGT is on a distinguished road
Go to crutchfield and buy the install kit. its like $20. If you have the mach system, its like n extra $15 for the adapter. if you have the mach, an aftermarket headunit, makes a difference of night and day
Old April 16th, 2011, 11:30 AM   #7
zdkel's Avatar
zdkel is on a distinguished road
I have found the adapters available at local stores like best buy and auto part stores and reasonable ~ $10. Check it out in your area. I put in a aftermarket sony in my mustang 2 years ago - plug n play.
96 GT - PI Intake & cams, O/R h-pipe, Flowmasters - 40s, Short Throw Shifter, 3.73 FRPP gears.
Threads Similar to: 96 Gt Aftermarket Radio Help
96 aftermarket radio mazza89 Audio/Video 1 March 23rd, 2010 09:51 AM
aftermarket radio StutteringStang06 2005 - 2010 9 October 4th, 2009 05:52 PM
ok aftermarket radio? Black02GT Audio/Video 9 May 14th, 2008 07:36 PM
aftermarket radio gooberhead320 Audio/Video 1 July 9th, 2007 03:29 PM
aftermarket radio gooberhead320 V6 Mustangs 1 July 9th, 2007 12:51 PM
