1998 Mustang GT
![]() iTrader: 2 reviews
What to do next???
So i recently just finished my full pi swap on my 98 GT. I also have 75mm throttle body, plemum, cai, msd. I want to get a tune but don't know how much it will cost me. Anyways. What should I do next? I want more power but with this compression ratio theres not much I can do. I also already have a pretty good suspension and getting lca's to add on soon.
So what next?
pi swapped and dropped sn95 |
Abyssinian of AX
'02 Saleen
19.34@42.259
You are upping HP/T... what have you done with your brakes?
Jazzer
1998 Mustang GT
nothing yet...I only have 16" wheels and no money for rims yet. I would rather spend money on performance/power than rims.
all i have for breaks are ceramic pads with powerslot rotors which i just did last year and I only drive it in summer/fall
1998 Mustang GT
bump
1998 Mustang GT
no one has any opinions on what to do next? At this point i am thinking taking the engine back out (yes again) and putting in a 5.4 or rebuilding my 2v with a turbo or going to a cobra motor. I want more power. So any ideas or opinions?
Rollin' 18/ pushin' 2
Gears.
1998 mustang gt
gears would be good built 2v with a turbo would be nice or a built 4v with a blower or turbo would be even better its all in how much $$$ your willing to spend
98 gt - pi h/c/i, 78mm t/b, bbk u/d pullies, tko 500 trans , frpp driveshaft , 4.10s 31 spline axels , still to slow time for a 4v ! TO DA BATCAVE!!
1998 Mustang GT
ya. i just dont have that kind of money seeing how I just spent a ton on this pi swap which i am regretting because I couldve put that to a blower or turbo on my npi. now im stuck with high compression or swapping my block with low compression pistons which is also in my head.
Traction...?
1996 GT/ 2008 GT Vert
Switch your npi heads back in and use a super charger
96 Mustang GT
B There 1 Day.
maybe the exhaust that would give you some decent horses if you do all 3 parts, longtubes with a shorty no cats and maybe a magnaflow catback with strait through mufflers. would sound badass too.
Could you put on a supercharger with a PI intake manifold and non PI heads/cams since it would have the stock compression but the PI manifold would still boost some horses?? Or would the PI intake manifold change the game of adding a supercharger??? I guess its not a big deal but instead of having complete non PI with a supercharger the PI manifold would add 10-15 HP along with the SC to give better numbers if it doesnt interfear with the operation of the SC ofcourse, but im unsure on the operation of this maybe someone with more knowledge can chime in.
![]() PI Manifold. FRPP. Steeda. Magnaflow. BBK. Accufab. RAM. MGW. MSD. NGK. NTK. Billet. J&M. Powerslot. Hawk. Walbro. Motul. Fel-Pro. Dupli-color. |
1996 Mustang GT Vert
![]() iTrader: 1 reviews
The use of a pi manifold and cams with npi heads works well for me with a supercharger. Although I just changed to a Bullitt intake so I have a pi intake C&L upper plenum and 70mm BBK throttle body for sale.
96 GT vert, Aftercooled Vortech, Lightning MAF,42# injectors, saleen cams, Bullitt intake, tune by Hitech, Magnaflow catback and O/R xpipe, Cobra brake upgrade, lowered bilstein suspension w/MM c/c plates and subframe connectors 3000 stall and 3.73's |
#12 | |
Did you pic up a lot of power with the bullitt intake over the PI intake?
I have not had a chance to get it on a dyno and see if they can tweak the tune yet and check power. Changed pulleys down one size as was told the boost goes down with the bullitt intake. Overall it idles better (had a rolling idle) and feels like it has better power. It sure looks meaner under the hood than the old setup!
Houston Bullitt
Definately long tubes, catted H and a tune ... that should net you 25-35 at the wheels with a good tune ..
2008 Bullitt #5072 JBA Stainless Longtubes, JBA catted H Pipe, BAMA Tune Via SCT, MGW shifter. Hot rod cams next. |
Traction...?
#16 | |
Houston Bullitt
This is the one I am getting to go with the long tubes..
1998 Mustang GT
just to update for those saying exhaust I already have an o/r h pipe with slp loudmouth (mufflers are basically open pipes haha). Along with the other bolt ons except gears and headers. (only two bolt ons i dont have) so maybe just a good tune would do good until i start the next build
Traction...?
I would do the gears. They will really help you get more out of your existing mods.
need tuned
10-4 on the gears !! 3.73 is a good gear if its a 5 speed 4.10 for the automatic !!
1 of 829 made Bright Tangerine Orange 10Lb Vortech V2,CXRacing FMIC MHS Stage 2 Blower cams,39# Injectors PI Intake,Ported and Polished NPI Heads BBK Headers,78mm BBK Throttle Body Mac H Pipe,2.5 inch Flowmaster Exhaust ,373 Gears |
