Discussing Cam Swap On SOHC 4.6 1998 GT in the 96-98 Forum. Thanks Noppe. I noticed that the otc tool was a pain, I used a 3/... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
#21 | |
Thanks Noppe.
ujst - bleeding them down was something i actually tried out to see what if anyting it would do for me. I had to do it in the pass side rear one because its barried under the cam girdle. I put it in a vise and slowly bled it off...but it comes back up to normal height, so it really didnt do much. except now i could push it down very slightly to get that extra hair to get my rocker on.
Ford/Toyota tech. -93 LX, X303 heads, F-cam, Trickflow u/l, 1.6 RR, FR wires, MSD cap/rotor, Elec. fan, a/c delete, smog delete, sn95 fuel rails with BBK regulator, 75mm TB and EGR, Vortech S-trim w/intercooler, 42lb inj/PMAS, 3.55's - |
#22 |
96 Mustang GT
Hey casper i put your number in my phone so dont freak out if i randomly call you, my number is 309-657-0721 so if anyone wants it they can have it and just a before hand warning casper im lowering my car coming up haha...just in case i go retarded and cant figure it out struts/shocks springs and all
IDK it wont work |
#23 |
Thats fine
#24 |
hey casper, just curious, what would you charge to do a cam swap
-BBK CAI, BASSANI CB + X, SCT 93 tune, 4.10s, Cobra brakes, Cobra R wrapped in nitto 555 tire. -College Football and studies take up the bulk of my time. |
#25 |
1998 Mustang GT
i just got my pi cams in today. i definitly feel some more power, although i dont think its the 15hp that some sources say u get. but for the $120 i paid for the cams, im very satisfied.
1998 GT PI cams bbk cai flowmaster 40's catback bbk x-pipe w/ cats march pulleys RAM clutch |
#26 |
you feel the seat of the pants power?
1997 Mustang Gt Convertible for sale. Triple black, great condition and unmolested!http://www.moddedmustangs.com/forums...like-most.html |
#27 | |
You really need the intake to feel the full potential because it flows SO much more air.
#28 |
1996 GT VERT PI at <3
Tell HMUSN he'll never catch me!!!
Location: "How does this thing work?"***BOOM***"Holy shit!!!, i just killed Zip!!!
Does anyone know where i can get a set of PI cams? Im doing the intake manifold swap and i figured i might as well put the cams in. I've been looking on the internet for 2 days now and all i can come up with are fully assembled heads.
#29 |
i can and i will PM you with a bunch of links. They are everywhere.
#30 |
thanks casper, i give u mad props for the help that you give to people like me. You've given me a whole better understanding to the 4.6.
#31 |
Also Casper, did u switch over to pi cams or did u use an aftermarket cam?
#32 |
14.631@93.51 @ 5800 FT
He went to a stage one setup! He got them for free or very little so he went that route!
![]() We expect shit to break, look foward to realizing exactly when it is happening, and than obsess about dropping plenty of cash to rebuild stronger, so we can try to run it hard as hell and break again. We are sick individuals.
#33 |
comp stage 1's. matt, u want to help me out here, are these the basic entry level aftermarket cam. The comp extreme or something like that. Cam's are a little new to me
#34 |
Yeah stage ones are the basic entry level cams from comp! Anyway if you step up to a more agressive cam like a stage 2 or 3 you have to get stiffer valve springs! I would suggest if you are going to be doing cams that you should go ahead and do the stage 2s if you have the cash, because they will show much greater results!
#35 |
It says that in order to uses the comp cams on a npi motor u need to put in new valve springs. Did u have to do this casper?
#36 |
for his stage 1s he did not! I dont know of one stage 1 cam that requires new springs! The stage ones are just similar specs as the stockers and that is why the change isnt required!
#37 |
Actually i went with some PI's i had laying around. I had them and another pair i installed in my buddys car. And the Stage 1's i sold. They were comp stage 1's for PI motor. and wouldnt work in my car.
Its a good idea to run new springs in a npi vehicle to avoid coil bind because these cars dont like high lift. OUr Npi vehicles are pushing the 60-100k mile range so new springs wouldnt be a bad idea anyways. But yes every stage 2 you need new springs.
#38 |
I know you can run 262ah (P.I) cam on a npi with a offset retainer >(crower cams). However this would be the biggest cam I would recommend of the AH comp series, on a higher reving engine a little valve float would mean time for new seals. I have found a way to run a .600" lift cam on a NPI head but it requires machining and the use of a different valve seal.
#39 |
i jsut got a 98 gt.....i wanna cam it...how big should i go and what brand?? i dont want it to be tooo big but i wanna notice and hear the
#40 |
Amazing write up. One of the best I've seen for cam installs. Wish I had seen it before I paid someone to put mine in. BTW I still have my PI cams in any of you non-pi guys are interested.
Threads Similar to: Cam Swap On SOHC 4.6 1998 GT
| 99-04 SOHC 4.6 | Invictus | Want to Buy | 4 | January 30th, 2008 08:24 PM |
| please help me 4.6 sohc gt | natedawgishot | 99-04 | 15 | September 18th, 2007 11:11 PM |
| 96 sohc swap to 04 terminator motor | 1quick96 | Modular Mustangs | 3 | March 20th, 2007 05:49 PM |
| SOHC to DOHC motor swap | Invictus | 99-04 | 15 | March 12th, 2007 12:08 PM |
| V8 4.6 SOHC | The eaglenator | General Tech | 6 | October 9th, 2006 11:17 PM |
