Discussing Cam Swap On SOHC 4.6 1998 GT in the 96-98 Forum. They came out of a 2004 GT. The car felt amazing after installing. The intake ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
#61 | |
They came out of a 2004 GT. The car felt amazing after installing. The intake didnt impress me much, but combined with the cams car felt very powerful. Very easy install and for 100 bucks of less for parts you cant go wrong.
White99stang-
93 LX, H/C/I + Vortech |
#62 |
aright thanks for the input guys sounds lk cams is a good choice
red 97 mustang GT |
#63 |
thats a good write up on the cam swap on the npi...it made me want to try my swap...no pi intake yet but its on the way...now when i changed out my cams i didnt have the ford tools to do it with..so i went for it...but i noticed when i got in there all i had to do was move as many lobes up so the valves are closed and wiggled the cam gears off ... i set the cam down ,i hooked a pair of vise grips in the middle while bolting down the front girdle,then once i got the cam bolted in on the front i turn the cam to line up the keyway notch so i could just slide the cam gears onto the cam...i know its kinda gettoredneckish,but it work out and i didnt have to fork over a 100 bucks for the tool...and it does run smoother,and sounds a lil diffrent cant really tell that the lil extra power is there but maybe when i throw the intake on i will,now as for saying the rear bolt on the valve covers has a 13mm bolt? all mine where 8mm or 5/16..same size,the only bolt that was diffrent was the dipstick case bolt 10mm?...maybe some have the diffrent sizes on the covers?...no car is the same ... but i gotta thank the guy that wrote this cam write up...thanks again man..and by the way im new to moddedmustangs site so ...HOWDY!!! everybody...lets race
#64 |
yoyoyo
#65 | |
Good job with the cams. they intake/cam swap really gives you some noticable power. Thanks for the comments on the writeup
White99stang-
#66 |
thanks casper...you seem like ya know your shyt when it comes to engines...i love pushrod engines (331)strokers mainly...anyways...with my 97mustang i have a few cookie cutter bolt ons like...ad.fuel press reg. set on 41psi.,x-pipe no cats,1chamber flows,u/d pulleys,accel coils,75mm tb,trick flow plem,with spacers on both,90mm lighting maf,cai,mac timing adjuster,a/c delete,lt headers,march fluid damper,sniper delta force programer inter face,42lb injectors,100hp shot of dry juice,pi cams,intake,...4.10 gears just aint put them in yet...well what im wondering is how much rwhp could i be making ...and also with those 42lb injectors...i know there to big for my combo...but will the bigger injectors make my 4.6 run to rich even though i can calibrate them to my mass air meter ...sniper tuning of course...ive heard people say that you can run a bigger injector...but the car well engine is only going to use what it has to???is this true or do i need to buy 19lbs to go back in her?...cause i did my intake swap today,& when i took out my injectors 4 of the injectors pental caps where cracked...i got the 42lbs off ebay and there like brand new...and was just wondering if i could throw them on there and not flood out the lil. 4.6...any feedback will be great ...thanks again man..l
#67 |
I put mine in a vise and gave them a squeeze. I've had no problems
http://i63.photobucket.com/albums/h1...ason/Pic_6.jpg |
#68 |
1996 GT VERT PI at <3
Tell HMUSN he'll never catch me!!!
Location: "How does this thing work?"***BOOM***"Holy shit!!!, i just killed Zip!!!
so I'm pretty much set to do the cam swap this weekend. I'm waiting on the cams, they should be here within the weeks. My question is how long sahould i expect this swap to take?
Don't thank us, Rep Us |
#69 |
1996 Mustang GT Premium
15.2@91
if i were to do this, what year mustang would be the best to get cams from?
#70 |
13.023@103.46 @ 5800 FT
01-04 but 99-01 will work too!
![]() We expect shit to break, look foward to realizing exactly when it is happening, and than obsess about dropping plenty of cash to rebuild stronger, so we can try to run it hard as hell and break again. We are sick individuals.
#71 |
15.2@91
casper said the press-on cam gears wouldnt work O_o
#72 |
then why did he use them in his install?
#73 |
15.2@91
i dunno :O lol
#74 |
Cuz he used romeo bolt on cams! But the presson cams will work, but you cant degree them!
#75 |
ok, so yesterday I did the PI cam swap with my friend. We didn't really romp on the car all that much, just made sure everything ran and there were no leaks. I could feel more power, but because i didn't romp on her, she really only felt like she was running smoother.
Well today i took the car out and ran her through some hell. cycled through the gears at 5400rpms up to about 100 then backed off in 4th. Combine with PI intake, Cams, and 4.10's my car pulled like of MOFO. She feels faster then my old 03GT, and 95Z28. I really drove the car for all she was worth today, and she just feels like she should. It's hard to decribe it, but the car runs so much better and I could actually hear a difference in the way she idles and revs. Between the Intake and Cams it was about 500 in parts and materials, and well worth it IMO.
#76 |
15.2@91
What year were your cams off of? And will someone explain to me the difference between bolt-on and press-on? You can't degree them as in adjust timing or ?? I'm still a noob x.x
#77 |
1996 mustang gt
what's the biggest lift cam that will fit a 96 gt without changing anything in the head.
#78 |
.550
#79 |
wow thats cool
#80 |
i am confused i though that a 1998 gt came with a sohc but in the pics there are 2 cames this would be a dohc. did he change the heads and the intake manifold. if they are diffrent how many valves per cylinders do they have.
Threads Similar to: Cam Swap On SOHC 4.6 1998 GT
| 99-04 SOHC 4.6 | Invictus | Want to Buy | 4 | January 30th, 2008 08:24 PM |
| please help me 4.6 sohc gt | natedawgishot | 99-04 | 15 | September 18th, 2007 11:11 PM |
| 96 sohc swap to 04 terminator motor | 1quick96 | Modular Mustangs | 3 | March 20th, 2007 05:49 PM |
| SOHC to DOHC motor swap | Invictus | 99-04 | 15 | March 12th, 2007 12:08 PM |
| V8 4.6 SOHC | The eaglenator | General Tech | 6 | October 9th, 2006 11:17 PM |
