Discussing Cam Swap On SOHC 4.6 1998 GT in the 96-98 Forum. will i even need to get that tool, and how does it work ?...
Old December 9th, 2007, 10:22 PM   #101
1996 mustang gt
eibach lowering springs,pro 5.0 short shifter,p.i intake,p.i cams,bassani x pipe.hope i can tune today!
soon to come, ford racing 4:10s,some boost !!!
Old December 10th, 2007, 11:52 AM   #102
atrains-gt's Avatar
Mine are Windsor cams as well. I may sell them and get some romeo cams or I may just use them. They were only $20.00
3.73 gears, K&N intake, MGW short shifter installed (PI intake,cams and suspension also in the works)
Old December 10th, 2007, 05:02 PM   #103
Casper98GT's Avatar
gtdan....you can get the tool and give it a try with it. But like i stated be very careful. If you mess up, then youre just gonna have to retime it. If you take the front cover off, you will have to do everything as well. With Romeo cams you can just zip off the bolt and zip-tie everything in place. Windsor cams you cant.
Ford/Toyota tech.
-93 LX, X303 heads, F-cam, Trickflow u/l, 1.6 RR, FR wires, MSD cap/rotor, Elec. fan, a/c delete, smog delete, sn95 fuel rails with BBK regulator, 75mm TB and EGR, Vortech S-trim w/intercooler, 42lb inj/PMAS, 3.55's -
Old December 10th, 2007, 06:13 PM   #104
1996 mustang gt
thanx bro!
Old February 9th, 2008, 05:19 PM   #105
Fastback91's Avatar
1997 Mustang GT Auto
3rd fastests car @ Highschool
so what did your car dyno?
Mustang GT:K&N CAI FIpk gen2,Magnaflow Mufflers, Alumnium IntakeManifold,Royal Purple performance Oil
Upcoming mods: dunno what ever i can get i guesss
maybe SFC
Old February 26th, 2008, 08:07 AM   #106
nice work,,mine was a 2000 with pressed on gears.had to remove front cover..and install bolt on cam gears,spacers,washers....
Old April 2nd, 2008, 12:25 AM   #107
1997 Mustang Gt
14.0 @ 99mph
Hey well 1st let me say you guys are the bomb to let others know info that's really hard to get when you are never near a shop or know what to do. I look in all the magazines and catalogs and they all say that the new pi intake doesn't fit the 96-98 heads but how did you do it. i'm planing to get the cams and intake but not swap the heads.
Old April 9th, 2008, 06:04 PM   #108
1998 Mustang GT
14.6 @ 96
okay i'm havin bigtime problems timing my car after the pi cam swap. anyone know a shortcut or secret to doin it?
Old April 9th, 2008, 06:15 PM   #109
1996 mustang gt
http://phatdoggy.home.comcast.net/~phatdoggy/sohc_timing.htm
maybe this will help you out ! good luck!!
Old April 13th, 2008, 11:56 AM   #110
Just did the cam swap using take outs from a supercharged pi saleen. At the same time I installed new seals, springs and had some valve spring retainers milled down for extra clearance. I haven't had it dynoed since before I did the pi intake swap using instructions from these forums, so we will see as I have an appointment for that tommorrow. So far I think it was worth it from a seat of the pants, we will see what the dyno says tommorow.
96 GT Convertable
vortech s/c w/aftercooler
98 Expedition
Old May 15th, 2008, 04:19 PM   #111
jlaw98gt's Avatar
1998 mustang gt
very slow and very boring
Where do i get that timing tool? and i think for now i might throw the stage I cms cams in it...i dont think i need new springs with those cams right?
ECCAFA
NJS
98 gt with a few bolt ons
Old May 15th, 2008, 04:57 PM   #112
dopeman(me)'s Avatar
96
.000000000000001
right on man
I got that vtech
Threads Similar to: Cam Swap On SOHC 4.6 1998 GT
99-04 SOHC 4.6 Invictus Want to Buy 4 January 30th, 2008 08:24 PM
please help me 4.6 sohc gt natedawgishot 99-04 15 September 18th, 2007 11:11 PM
96 sohc swap to 04 terminator motor 1quick96 Modular Mustangs 3 March 20th, 2007 05:49 PM
SOHC to DOHC motor swap Invictus 99-04 15 March 12th, 2007 12:08 PM
V8 4.6 SOHC The eaglenator General Tech 6 October 9th, 2006 11:17 PM
