Cam Swap On SOHC 4.6 1998 GT - Page 7
LinkBack (15) Thread Tools
Old June 21st, 2010, 12:56 PM   #121
maxium's Avatar
maxium will become famous soon enough
Originally Posted by 93HatchsBFF View Post
so what year again did the PI cams come with pressed on cam gears? and on the 96-98 with the PI complete swap what are the 1/2 mile times average?
I believe the Romeo engines (03-04) had the bolt on cam gears while all the Windsor type (99-03) had the pressed on gears (I think there was some overlap in Romeo/windsor types in 03).
Old June 22nd, 2010, 05:13 PM   #122
93HatchsBFF's Avatar
1989 LX
12.60 at 109mph
93HatchsBFF will become famous soon enough93HatchsBFF will become famous soon enough
dang that sucks. and with aftermarket cams do they come with the cam gears on them or do we gotta put them on and degree them ourselves?
1989 LX mustang, 5speed, 108,xxx miles, Mac Longtubes, BBK midpipe, Paxton Novi 1000 6psi, Crappy FMU with 19lb injectors, 373 gears
soon to come
30lb injectors, Blow through MAF, intercooler and tune
Old June 22nd, 2010, 05:32 PM   #123
1989 LX
12.60 at 109mph
Also with the PI head swap and PI cams do you need a tune afterwards or would it be fine?
soon to come
Old June 22nd, 2010, 06:01 PM   #124
The Hammer
G.T. Rags's Avatar
Millenium Falcon
G.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant future
if you are running stock pi cams and heads you won't require a tune.... hell, even with aftermarket parts you can get away with no tune. stock parts it won't be so ruff, but with the aftermarket stuff it will. and you won't be utilizing your parts to there full potential. you could prolly squeeze 5-10hp out of a stock car and 20 or so out of a modded one
I would eat the peanuts out of her shit
Car Salesman Club - The Hammer
ModdedMustangs Conspiracy Group: President
Old June 30th, 2010, 06:14 PM   #125
zdkel's Avatar
zdkel is on a distinguished road
well I took delivery on used PI cams, and I got that itch. So what y'all are saying is (on a stock 96) bolt them in and go, right? Well and swapping in the PI intake of course.
96 GT - PI Intake & cams, O/R h-pipe, Flowmasters - 40s, Short Throw Shifter, 3.73 FRPP gears.
Old June 30th, 2010, 09:04 PM   #126
The Hammer
G.T. Rags's Avatar
Millenium Falcon
pretty much....
Old July 12th, 2010, 01:55 AM   #127
starin is on a distinguished road
casper can you do a much more detail write up like this for a guy whose never dont this before? i want to buy the 2 tools you used so i can do this without taking the timing cover off, theres a few things im lost about. thanks so much if you can.
KNN FIPK kit, Hid headlights, MGW short shifter, Offroad BBK x-pipe, 4.10 gears.
Old July 12th, 2010, 06:46 AM   #128
1996 Mustang GT Vert
Blower Head is on a distinguished road
The two tools I think you are referring to are : cam tension retention tool you can get from Anderson motorsports and a ford valve spring tool (got mine from amazon).
96 GT vert, Aftercooled Vortech, Lightning MAF,42# injectors, saleen cams, Bullitt intake, tune by Hitech, Magnaflow catback and O/R xpipe, Cobra brake upgrade, lowered bilstein suspension w/MM c/c plates and subframe connectors 3000 stall and 3.73's
Old January 20th, 2011, 06:40 PM   #129
wrenchhog44's Avatar
1998 Mustang GT
wrenchhog44 is on a distinguished road
Special tool?
Would love to get the part number for that tool to hold the timing chain in place if you get a chance.
When in doubt, go by the rule of dog...
If you can't eat it or f*ck it, just piss on it and walk away.
Old January 20th, 2011, 07:53 PM   #130
NeverEnuff's Avatar
1989 LX Coupe
7.1@99mph
NeverEnuff has a spectacular aura aboutNeverEnuff has a spectacular aura aboutNeverEnuff has a spectacular aura about
I didn't read all replies...sorry. But I saw about the cam gears.
96-98 GTs were bolt on gears (romeo)
99/00 GT were press on gears, truck motors (windsor)
mid-01-04 GTs were bolt on as well.
Basically Windsor motors came in trucks were all pressed on gears. Mustang cars got the truck motors from 99/00, hence the pressed on gears...If you have a romeo motor. Pressed on gears.
89 LX Coupe-Carb'd 32v-437rwhp NA, 592rwhp N20
01 Bullitt-32v swapped
96 GT-Cammed E85
www.KPERacing.com
Old January 21st, 2011, 02:34 AM   #131
Buck91 is on a distinguished road
Check out AFM. I used their tool and it worked GREAT. Two tips though.
1. DONT USE WITH AFTERMARKET CAMS as they should be properly degreed
2. Follow the instructions. Turn the crank to "suck" the tool in, its not a pry bar
1996 Mustang GT 5spd - PI Cams, Bassani OR X pipe, Dynomax Ultraflow mufflers, C&L plenum with 75mm TB, K&N FIPK, PIAA 1700X foglamps.... More to come.
Old January 22nd, 2011, 02:14 PM   #132
1998 Mustang GT
Thanks a lot.
Old January 23rd, 2011, 11:23 AM   #133
1998 Mustang GT
Originally Posted by MustangMatt96GT View Post
but who knows how to degree a cam, let alone has ever heard of it. Especally since a broad majority of owners of the NPI cars are under 25
You may be surprised. Most, if not all of the gearheads I hang out with are well aware of the term and what it means, they simply lack the knowledge to perform such an operation.
Old January 23rd, 2011, 12:09 PM   #134
mach1soldier's Avatar
mach1soldier is on a distinguished road
I couldn't agree more. All of my friends are young as well but they all know what degreeing is. The process and tools though is what keeps them from doing it.
2003 mach 1 12.7x @103 4600 stall, 4:30, slicks & skinnies, ALUM DS, VMP tune.
1996 ford thunderbird (13.02 @104) pi block, all the bolt ons minus cams, 3.73, 3800 stall.
Old February 25th, 2011, 08:19 AM   #135
dbeesokc is on a distinguished road
Thumbs up
Transmission
Originally Posted by noppe180 View Post
nice write up
I also have a 98 Gt Convertible, is yours auto or manual? If auto, have you had any transmission work done on it? Shift kit? Rebuild? Mine is beginning to show some signs of wear and I was just wondering what others had experienced in this arena.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/96-98/21676-cam-swap-sohc-4-6-1998-gt.html
Cam Swap On SOHC 4.6 1998 GT This thread Refback April 26th, 2012 01:04 AM
non-pi heads and pi cam question | Mustang Forums at StangNet This thread Refback February 22nd, 2012 01:49 PM
NPI to PI Cam/Manifold Swap HOW TO | Mustang Forums at StangNet This thread Refback December 18th, 2011 11:52 AM
Ford 4.6L SOHC Camshaft Swap This thread Refback March 13th, 2011 11:01 PM
Ford 4.6L SOHC Camshaft Swap This thread Refback March 13th, 2011 07:10 PM
NPI to PI Cam/Manifold Swap HOW TO - Mustang Forums at StangNet This thread Refback July 29th, 2009 12:42 PM
non-pi heads and pi cam question - Mustang Forums at StangNet This thread Refback July 28th, 2009 09:15 AM
Cam Swap on a SOHC 1998 Gt - UnitedMuscleCars This thread Refback March 17th, 2009 02:56 PM
Central Florida Ponysports Forums-viewtopic-anyone done a cam swap? This thread Refback February 18th, 2009 04:49 PM
Cam Swap on a SOHC 1998 Gt - CFMPerformance.net This thread Refback September 13th, 2008 06:38 AM
NPI to PI Cam/Manifold Swap HOW TO - Mustang Forums at StangNet This thread Refback July 25th, 2008 03:54 PM
non-pi heads and pi cam question - Mustang Forums at StangNet This thread Refback July 22nd, 2008 11:59 AM
Camshaft Choices - Mustang Forums at StangNet This thread Pingback July 21st, 2008 01:23 AM
non-pi heads and pi cam question - Mustang Forums at StangNet This thread Refback June 5th, 2008 11:30 PM
NPI to PI Cam/Manifold Swap HOW TO - Mustang Forums at StangNet This thread Refback May 9th, 2008 11:03 AM
Threads Similar to: Cam Swap On SOHC 4.6 1998 GT
please help me 4.6 sohc gt natedawgishot 99-04 16 October 15th, 2011 07:32 PM
96 sohc swap to 04 terminator motor 1quick96 Modular Mustangs 3 March 20th, 2007 05:49 PM
SOHC to DOHC motor swap Invictus 99-04 15 March 12th, 2007 12:08 PM
V8 4.6 SOHC The eaglenator General Tech 6 October 9th, 2006 11:17 PM
