NPI Build
Old May 13th, 2011, 04:44 AM   #1
2001 Mustang GT
DsmDave is an unknown quantity at this point
NPI Build
well guys I am coming to you for help. I have a PI motor in my car now and am swapping it for an NPI motor. Here is what I already know I will swap. I plan to go for a good nitrous/boost motor.
PI intake manifold swap
new gaskets all around
PI or a set of aftermarket cams price pending
any good pistons recommended? good set of rods? is it even worth touching the bottom end?
next question is can i use the harness with my NPI motor to use the coilpacks or just rip that shit off and use my COP harness?
bbk longtubes, bassani x, borla stingers, AM intake,bbk throttle body, Under drive pullies,Zex wet 125hp kit SCT Tuned by bama and drag radials, drag springs, agx shocks, lower control arms, subframe connectors
MM+Cleavage Club #26
Old May 13th, 2011, 06:09 AM   #2
1998 Mustang GT
13.046@107.49
cruizer will become famous soon enough
If you still have your COP valve covers then you you should have no problem using your COPs and harness
98 Mustang GT 13.795 @ 98.87 N/A
Main mods: PI Swap, 3.73 gears, E85
My Mark VIII and T56 swap
Old May 13th, 2011, 03:00 PM   #3
2001 Mustang GT
That's what I was hoping would swap over. I think cop is cleaner than the coil packs. I got a npi motor with 46k on it so I'm just gonna do a little budget build while I still drive my pi
Old May 13th, 2011, 03:02 PM   #4
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.65 @ 115
sharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud of
iTrader: 10 reviews
why are you putting a npi motor in? Whats the point?
No reason to mess with the bottom end on a npi motor. Its slow as ballz
410rwhp 520rwtq @ 12.9 psi
Old May 13th, 2011, 03:05 PM   #5
2001 Mustang GT
Its getting. A full pi swap and all bolt ons before it goes in. New gaskets and such. I think its easier to build this motor on a stand than in the car plus with a full tranny and motor it was only 400
Old May 13th, 2011, 03:07 PM   #6
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
$400? Damn, I'm NEVER gonna be able to sell my old motor.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old May 13th, 2011, 03:10 PM   #7
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.65 @ 115
iTrader: 10 reviews
We can put it in my go kart
Old May 13th, 2011, 03:10 PM   #8
2001 Mustang GT
I just got a good deal. I'm gonna part out the wire harness and Ecuador it came with a-d someno pi stuff to get some cash for mods.
Old May 13th, 2011, 03:17 PM   #9
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
I would almost be willing to GIVE it to you just to see that.
MODS IN GARAGE
NCMM ORIGINAL
Old May 16th, 2011, 09:38 PM   #10
2001 Mustang GT
well here are some pics of my motor and new setup?
Old May 16th, 2011, 10:20 PM   #11
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
port the npi heads, cut the guides down, good cams, pi intake, and go. the npi heads are better flowing heads if you lift the valve .550 and helps with compression as well. any good name brand rod/pison would be good choice to get.
Old May 16th, 2011, 10:31 PM   #12
2001 Mustang GT
im looking at just building this as my my motor to learn on before I do my 4v.
I planned doing the PI intake manifold swap. what would lifting the valves bring my compression to about? how weak is this crank? Will I be able to get 450 wheel safely on a blower?
Old May 16th, 2011, 11:04 PM   #13
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
the valves dont effect compression. the npi heads just flow little better about .530 lift if they are ported right and cut guides. as for the cranks, cast cranks will do 600rwhp all day long no porblem as long as tune is right.
Old May 16th, 2011, 11:09 PM   #14
2001 Mustang GT
Thanks for the advice. That sounds like it willpower be more than enough for a few low 11 sec passes
Old May 16th, 2011, 11:24 PM   #15
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
depends on compression and set up. the npi head is plauged with larger umbustion chambers, so a s et of flat tops would be a good idea to get compression up. also think about future, if you go to a pi head then compression ratio will change drastically.
Old May 16th, 2011, 11:33 PM   #16
2001 Mustang GT
I have a pi motor in my car now. This is being built as a boost motor so the lower the better for me.
Threads Similar to: NPI Build
5.4 GT build thread DickH 4V / SVT 128 December 19th, 2011 02:52 PM
95 Build 97gtmustang 5.0 Mustangs 13 March 5th, 2011 10:05 PM
4.2 build SleeperStang88 V6 Mustangs 4 October 8th, 2009 11:04 PM
V6 build up rebcavstang V6 Mustangs 9 July 19th, 2009 11:35 PM
