24# injectors ?!?
Old May 16th, 2011, 11:45 AM   #1
fsttang96's Avatar
need tuned
fsttang96 is on a distinguished road
24# injectors ?!?
Well after some long thought I decided what im going to do to the stang !! I started ordering parts so far i ordered BBK shorty headers,BBK throttle body / plentium, PI Intake , Bullit stage 2 cams from MHS, CXRacing cooler for the supercharger and a pulley for the supercharger to get it around 10# of boost and a little porting of the NPI heads !! I want to put 24# injectors in but I am unsure of the ford part number does anyone know what that number is ? I think it is XF1E-A5B but just want to make sure I buy the right ones !! Or will the stock injector be sufficiant ?!?!
1 of 829 made Bright Tangerine Orange
10Lb Vortech V2,CXRacing FMIC
MHS Stage 2 Blower cams,39# Injectors
PI Intake,Ported and Polished NPI Heads
BBK Headers,78mm BBK Throttle Body
Mac H Pipe,2.5 inch Flowmaster Exhaust ,373 Gears
Old May 16th, 2011, 02:45 PM   #2
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
You should be running a minimum 30# injector if your using a supercharger. Adding a better intake and cams along with port and polish work on your heads you should look into a set of 42# injectors.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old May 16th, 2011, 09:28 PM   #3
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
42's little far for just 10lbs of boost and a mild set up, but would be more ideal.
Old May 17th, 2011, 08:07 AM   #4
1996 Mustang GT Vert
Blower Head is on a distinguished road
42# injectors and a 90mm lightning maf make a good combo.
96 GT vert, Aftercooled Vortech, Lightning MAF,42# injectors, saleen cams, Bullitt intake, tune by Hitech, Magnaflow catback and O/R xpipe, Cobra brake upgrade, lowered bilstein suspension w/MM c/c plates and subframe connectors 3000 stall and 3.73's
Threads Similar to: 24# injectors ?!?
Injectors SilverGT04 99-04 7 December 10th, 2007 02:22 PM
Injectors chickenbot 5.0 Mustangs 14 December 7th, 2007 01:22 AM
