antitheft problem
Old May 17th, 2011, 03:15 PM   #1
birddog55 is on a distinguished road
antitheft problem
I bought this 96 ft thinking it needed a fuel pump so I towed it home and put a new fuel pump in it and the car will start and then dies. The antitheft light just flashes at a fast pace. The key is just a key cut from a hardware store and not a factory key so I was wondering if this is a antitheft issue? The ignition were you put the key at the plastic piece spins around also maybe some ignition issue. Any help would be appreciated. Thanks
Old May 17th, 2011, 03:59 PM   #2
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
Your car has a P.A.T.S key from the facrtory. A traditional key will not start the car. It will turn over and over and over but never run. You can get a new pats key from the dealership and it will need to be programmed to the car by the dealer as well.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old May 17th, 2011, 04:47 PM   #3
98REDGT is an unknown quantity at this point
Exactly
1998 GT. Headers with catless X-pipe into flowmasters. CAI. Cobra wheels 17x9 with 245/40's and 17x10.5 with 275/40's. 04 GT leather interior.
Old May 17th, 2011, 05:06 PM   #4
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.65 @ 115
sharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud of
iTrader: 10 reviews
So pretty much the key you have for it is worthless.
Whatever key you copied you need to use to start it
410rwhp 520rwtq @ 12.9 psi
Old May 17th, 2011, 10:42 PM   #5
I bought the carfor a friend and drove it to his house the key had tape around the top of it. I just asked my buddy why he took the tape off and asked if it had a chip in the tape and he said it didn't. So did all these cars come with chipped keys? Thanks for helping a newbie out.
Threads Similar to: antitheft problem
misfire problem, probelms, probably a problem? rewadferger 96-98 5 September 13th, 2010 12:17 PM
just solved my evap problem now a more serious problem arises I NEED HELP please sj408 96-98 5 July 16th, 2010 08:12 PM
Transmission problem??? need help diagnosing the problem... Tmac3320 99-04 19 April 13th, 2009 12:58 AM
Ford Antitheft shadowgames81 99-04 5 October 25th, 2008 04:42 PM
umm have a weird problem? idle problem? blue03mach1 99-04 16 March 4th, 2008 12:03 PM
