98 maf Details
Old May 21st, 2011, 09:48 PM   #1
1989Gt.'s Avatar
1989 Mustang GT
1989Gt. is on a distinguished road
Send a message via AIM to 1989Gt. Send a message via Skype™ to 1989Gt.
98 maf Details
Hi i was wondering if how i can run 24lb injectors.... Without a tune? I have the 19lb injectors on right now with stock ecu and maf but what do i need to do to run 24lb can i just swap out the maf and injectors and be done?
Old May 22nd, 2011, 12:03 AM   #2
1998 Mustang GT
MustGT98allday will become famous soon enough
maf and tune
pi swapped and dropped sn95
Old May 22nd, 2011, 10:45 AM   #3
98REDGT is an unknown quantity at this point
Is there a reason to do this?
1998 GT. Headers with catless X-pipe into flowmasters. CAI. Cobra wheels 17x9 with 245/40's and 17x10.5 with 275/40's. 04 GT leather interior.
Old May 22nd, 2011, 11:12 AM   #4
1998 mustang GT
ron98gt is on a distinguished road
I think that with a tune it produces the proper spray thru the selected size fuel injector. If you put on 24,s the amount of fuel for the proper spray would be comming out for the 19lb not the 24 and would not increase you fuel for your mods if any this may burn poorly.. Thats just what I think.
98 gt blk on blk 90k miles with BBk 75mm throttle body, C&L plenum, Diablosport predator,powerdyne supercharger & a few other things.
Old May 23rd, 2011, 08:26 AM   #5
All Motor 1998 GT
cstreu1026 will become famous soon enough
You can run 24# injectors with the stock MAF but you will need a tune to make it work right. What do you want to run the 24's?
Old May 24th, 2011, 02:06 AM   #6
1989Gt.'s Avatar
1989 Mustang GT
Ok I just w anna kno if i can change the maf and injectors and the computer will be ok?
Old August 31st, 2011, 08:39 PM   #7
1989Gt.'s Avatar
1989 Mustang GT
bump im gonna be making roughly 330whp now and i need to know if im gonna need to up to 24lb injectors, and what i need to make them work right
Old August 31st, 2011, 08:49 PM   #8
All Motor 1998 GT
Yes, you will need bigger injectors. I ran out of injector just shy of 300 RWHP. Thanks to modern tuning software you only really need a set of injectors but you could also get a properly calibrated MAF like a PMAS/Pro-M.
Old August 31st, 2011, 09:12 PM   #9
1989Gt.'s Avatar
1989 Mustang GT
So i wont need tuning?
Old August 31st, 2011, 09:18 PM   #10
All Motor 1998 GT
You are going to need tuning regardless because you are making a lot more power than stock. What are the details on the car?
Old August 31st, 2011, 09:41 PM   #11
1989Gt.'s Avatar
1989 Mustang GT
It has a cobra swapped rebuilt with a 10.8:1 compression ratio, i was gonna get a tune anyways but not right away so i need to know if ill be able to drive it right away
Old August 31st, 2011, 09:51 PM   #12
1989Gt.'s Avatar
1989 Mustang GT
I mean is cobra swapped.
Old September 1st, 2011, 10:08 AM   #13
Tang Stang's Avatar
Tang Stang is just really niceTang Stang is just really niceTang Stang is just really niceTang Stang is just really nice
Like the others have already said multiple times, you'll need a tune to run the 24# injectors correctly. That is all there is to it.
Rod @ AzzKicker Cars
2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's.
1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC.
1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch
Old September 1st, 2011, 10:11 AM   #14
1997 cougar 4.6 1/2PI
TooFast4theFUZZ
OptionalStang will become famous soon enough
buy my 24lb injectors and tuned mafs and stuff..then you got a start
Old September 1st, 2011, 02:25 PM   #15
1989Gt.'s Avatar
1989 Mustang GT
No thanks i have a set that i can get. But i was just wondering because with the fox bodys all you have to do is switch the maf and injectors and it changes by itself i dont know how the computers work in these cars.... what are stock 19lb ers goood up too hp wise
Old September 2nd, 2011, 08:03 PM   #16
TooFast4theFUZZ
im not exact but i kn ow 19's will take you pretty far..atleast 260hp...
Old September 5th, 2011, 04:19 PM   #17
1989Gt.'s Avatar
1989 Mustang GT
well ill be way past 260.... So thats why i was looking for a diagram
Old September 6th, 2011, 08:43 AM   #18
Tang Stang's Avatar
A diagram of what?
Old September 6th, 2011, 03:22 PM   #19
fsttang96's Avatar
need tuned
fsttang96 is on a distinguished road
19 pound injectors are good up to 305 hp !!
1 of 829 made Bright Tangerine Orange
10Lb Vortech V2,CXRacing FMIC
MHS Stage 2 Blower cams,39# Injectors
PI Intake,Ported and Polished NPI Heads
BBK Headers,78mm BBK Throttle Body
Mac H Pipe,2.5 inch Flowmaster Exhaust ,373 Gears
Old September 6th, 2011, 09:32 PM   #20
p4ndiamond's Avatar
1997 Pacific Green Cobra
14.80 No traction
p4ndiamond will become famous soon enoughp4ndiamond will become famous soon enough
I would never run them up to 305hp then you would be using the full duty cycle of them .
GT ENGINE (temporary) 4.30 Gears , 31 spline Moser axles , Detroit tru Trac diff, Jmod 4r70w , Pi intake Hitech stage 2 cam, Vortech V2 3.33 pulley. Alum drive shaft. Lowering kit x2 ball joints ,screamin demon coils, LCA "
Threads Similar to: 98 maf Details
T5 transmission details brinkley396 V6 Mustangs 5 April 21st, 2011 01:16 AM
Detail Write-Ups M.P. Cobra Fan General Car Care & Detailing 0 December 22nd, 2010 11:02 PM
Details On Fixing My Car 99v6stang V6 Mustangs 5 November 27th, 2007 01:56 PM
A couple new little details neckbonekat 99-04 36 September 5th, 2007 02:59 PM
Ok details please... QuEeNiEsTaNg The Clubhouse 1 January 20th, 2007 08:30 AM
